How hot do differentials/ pumpkins get?
Discussion in 'Ask An Owner Operator' started by 77fib77, Jun 7, 2024.
  1. 77fib77
    77fib77 Road Train Member
    11,696
    77,291
    Jul 7, 2010
    St Louis
    My differential was at 168'F via laser temp gun. Im at 72k lbs and 33.4k on the drives. Is that too hot? My tires were 140 to 150'F. It's 95'F in Mississippi.
    blairandgretchen and austinmike Thank this.
  3. AModelCat
    164,924
    I wouldn't worry about that at all. If you were up over 200-210°F I'd start to take notice. Once oil approaches 250°F you're getting into territory that starts to damage parts and cook the oil.
  4. Arctic_fox
    4,538
    25,659
    Sep 16, 2016
    Mine usually hover around 160-170f when im pulling a full 80K and it is not unusual to see it spike as high as 200 on a long mountain pull at 80k either. Like cat said unless it stays around 200 dont worry about it.
    77fib77 Thanks this.
  5. 77fib77
    11,696
    77,291
    Jul 7, 2010
    St Louis
    The pumpkin temp doesn't get me and much as the tire temp. I have recaps on the drives. They have Goodyear caps and Goodyear or Michelin casings. I know I need to buy virgin at some point. But they are expensive.
  6. Cat sdp
    Cat sdp . .
    21,317
    76,324
    Apr 8, 2012
    Orion's Belt
    Just curious…. Were both diffs the same temp…?
    asking for a friend
  7. 77fib77
    11,696
    77,291
    Jul 7, 2010
    St Louis
    Nope front was hot and rear was cooler.
    blairandgretchen Thanks this.
  8. Animosus
    Animosus Heavy Load Member
    733
    2,916
    Dec 7, 2015
    SE Wyoming
    Front will always run hotter.
  9. Long FLD
    Long FLD Road Train Member
    12,926
    54,245
    Mar 4, 2015
    I wouldn’t worry about 170. We used to peg both rear ends into the red dropping down Whitebird at 105k in the summer.
    Deere hunter and 77fib77 Thank this.
  10. Magoo1968
    Magoo1968 Road Train Member
    2,061
    5,491
    Mar 18, 2021
    St Malo mb
    We change diff oil every 500 k and they last well over 1.5 million running 35% mountains 65% prairies.. Boss rarely sells a truck he maintains them extremely well instead so some have major miles on them. PS because we run mountains a lot he makes sure every truck has a manual fan switch which helps tremendously on tough pulls .
    Deere hunter and Concorde Thank this.
  11. bad-luck
    bad-luck Road Train Member
    3,442
    6,345
    Nov 16, 2013
    Baltimore, Maryland
    The hotter it is outside, the hotter your rears will run. The front will always run hotter than the rear. Weight and terrain will also effect the temperature. 168° is normal.
    77fib77 and Deere hunter Thank this.
