How is the 4900ex?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by naval_superman, Feb 25, 2017.
  1. naval_superman
    naval_superman Bobtail Member
    21
    6
    May 24, 2016
    Been thinking About trucks I could possibly buy in the future to occupy my mind. Looking at ordering a 4900ex with either a DD13 or 15 and a 10 speed.
    Any of you guys have a 4900ex? If so how do you like them?
  3. Ridgeline
    22,724
    123,366
    Yes, nice trucks, ISX with 18 spds.
    Will never have a 10 or 15, 13 or 18 and that's it.
  4. Scottyboy
    Scottyboy Light Load Member
    Nice choice-in my opinion.I owned a 07,18sp,cat c15.One tough truck.Bought it at 400k-traded it in at 815k.No major problems(we treated each other well).
    I will purchase another one-end of 2017.Good choice n good luck.
  5. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    Why would you order a 10 speed? 13 or 18 is the only answer.
  6. naval_superman
    21
    6
    May 24, 2016
    I've been driving a 13 speed here for a little bit and have had nothing but issues. Might be because the truck is used, but has been nothing but a pain.
  7. fortycalglock
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    Not to derail the thread, but what kind on issues. My current one has 1.5 mill with no issues and my previous truck had 1.2 mil with one minor blip.
  8. naval_superman
    21
    6
    May 24, 2016
    Might be me and not the trans, but it'll kick into neutral when I split certain top gears.
    Like I said, could just be user issue, but a good example is I'm climbing up a hill and have to go to low 10, then I go down hill and try to switch to 10 high, it won't go. It's just rolls down the hill in neutral. I'll floor it and the RPMs stay steadily at 14. If I try to switch to 10 high while this is going on and I step on the fuel to engage it into gear, it'll rev up to the 20s while grinding like hell before knocking strongly back into gear.
    Another issue is when I'm switching from 5 low to 4. Sometimes it doesn't lock into gear even tho it's in the hole. It'll do the same thing, I give it fuel, grinding revs in the 20s then knocking into gear.
    Again, could just be user error! If so I'd like to know how to fix it
  9. haycarter
    haycarter Road Train Member
    1,920
    5,317
    Jun 9, 2012
    Australia
    ^^^^^^^^^ I'd suggest giving the Gearbox's Air system a Good overhaul...
    ChicagoJohn Thanks this.
  10. Ridgeline
    22,724
    123,366
    Yeah it sounds like you have either an air issue or an electrical issue. Either way, it isn't normal.
  11. ChicagoJohn
    ChicagoJohn Road Train Member
    2,390
    2,755
    Jan 14, 2016
    Chicago
    That's certainly not normal.
