How long batteries last ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Greggg, Sep 15, 2019.
  1. Greggg
    Greggg Light Load Member
    161
    35
    Jun 30, 2018
    If I turn off my inverter, (I have a 4.5cu fridge) and everything else in my truck, how long would my batteries last (I have 4 of them) before I would need to be jumped ?
    (My batteries usually last 12hrs with the inverter/fridge on)
    If my batteries do die can a regular small sedan jump start me ? (Even if might take a longer time ?)
    I have a 2005 freightliner can’t find the battery kill switch and don’t know if the truck would shut itself off to keep enough power for me to start it...
  3. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    A small sedan, while not recommended, can jump start a truck. It can take several hours depending on how dead the batteries are. But it can do it. Jump started a Freightliner in 1990 with a 4 cylinder Buick Skyhawk. Roughly 5 hours for that one.
    HoneyBadger67, pushbroom and Greggg Thank this.
  4. SpeedyGonzalez
    SpeedyGonzalez Light Load Member
    123
    59
    Dec 28, 2017
    One of our rigs has 4 batteries as well, with the fridge shutoff I see about .2 volts drop every night, you really dont want to let the battery get below 11.6v or itll be a pain in the behind to get started, at 11.2v mine will crank much slower and I'll get a ECM power low on the dash. I usually get 5 days before it needs to be jumped. I can jump it with my pickup in about an hour, if you've got a good set of cables when you hook up to the jump terminals you should hear the engine load up. Most alternators only make a few amps at idle, my truck puts out 160amps at 1500rpm so I just use a stick and slide the seat forward to keep the pedal depressed.
    Greggg Thanks this.
  5. Greggg
    161
    35
    Jun 30, 2018
    Thanks a lot for all that info speedy. Definitely you too rusty thanks.
  6. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Almost 2hrs to jump start my T660 (4 batteries, 2 of which were bad) with a Camry...LoL
    RustyBolt and buddyd157 Thank this.
  7. thaistick
    thaistick Road Train Member
    1,416
    1,737
    Dec 7, 2014
    OTR/Thailand
    If you've got good batteries and everything is off....you could go months. How long are you going to be away? If more than a week or so, I'd disconnect the batteries, so that there wouldn't be a parasitic drain.
  8. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    I think key is using heavy duty jumper cables....
    With a high idle on your vehicle..
  9. Greggg
    161
    35
    Jun 30, 2018
    Cool that’s good to know too.
    Just in case info helps someone I’ve ran my fridge and other too long before to the point where even the inverter and fridge shut off a dually had me started in about 15 minutes I’d say with the regular jump cables they have at Walmart.
  10. PE_T
    PE_T Road Train Member
    I’ve been thinking another option to have a fridge in the truck and not risk damaging the batteries is to buy a mini freezer, an inverter, and an ice box. You will be freezing bottles of water or (blue) ice packs while driving. On every 10 hr break, you turn off the freezer, and move the frozen ice packs to the ice box.
  11. SpeedyGonzalez
    123
    59
    Dec 28, 2017
    The great fridge dilemma lol, we ended up going with a deep cycle battery in the side box isolated with a control relay and switching relay. If the truck isn't running the fridge runs off of just the deep cycle, once system voltage is up to 12.6V control relay trips and they're all chained together and charging. Nice part is if the main batteries are weak, the driver can hit a button on the control relay and has an extra battery for starting. Cost was $30 per truck excluding batteries and cables.
    PS. The fridges in the trucks use a peltier module which are highly inefficient, if you shop around you can usually find a mini fridge that uses a compressor that runs at 5-6 amps. Those will cool better and faster and are more efficient, and usually have a larger volume for the same power draw of the peltier ones. You can also modify them with a big capacitor to reduce the inrush current requirement if your inverter cant keep up.
    PE_T Thanks this.
