How long before rebuild on a 3406c
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mr79W900A, Mar 6, 2025.
  1. Mr79W900A
    Mr79W900A Light Load Member
    121
    72
    Mar 4, 2019
    British Columbia
    Hey guys I have my 3406c mechanical 3zj 425hp. It’s got around 400k that’s kilometres not miles. and 12k hrs now. How many hrs will these go before a rebuild roughly. It’s in a dump body which is why I ask in hrs. Or should I not worry about hrs and just go by kms. Also should I roll
    In bearings or just run it. Thanks
    W923 Thanks this.
  3. Lazer
    Lazer Road Train Member
    1,850
    2,983
    Jan 22, 2017
    For most local construction type trucking, most go by engine hours. Depending on the engine, the capacity of the crankcase, and how much off road work is done would be the main factors determining engine maintenance.
    If you are 12k hours now, if oil consumption is minimal, power is good, etc., I imagine you are 1/2 way to need of an overhaul, maybe longer. Be meticulous on your preventative maintenance, use the highest quality oils and lubricants you can afford.
    W923 and Bean Jr. Thank this.
  4. 062
    062 Road Train Member
    6,347
    34,012
    Oct 20, 2013
  5. W923
    W923 Road Train Member
    1,426
    4,421
    Feb 28, 2022
    If the maintenance was decent id guess you have quite a bit more time left in it…. A bearing roll probably wouldn’t be a bad idea but depending on who does it and how clean they keep things it has its risks
    I have a 3zj that I pulled out of a truck with 800k and it had never been opened (everything had matching date codes) it was originally an over the road truck and later a local truck so probably had fairly high hours. Must have been maintained pretty well because everything inside looked great (bearings were showing wear but looked normal) I put bearings and injectors and resealed some stuff and put it in another truck.
