how long for heat
Discussion in 'Trucks [ Eighteen Wheelers ]' started by moparcas360, Jan 13, 2012.
  1. moparcas360
    moparcas360 Bobtail Member
    34
    7
    Oct 15, 2010
    Fraser,MI
    My 96 volvo takes 45 minutes to put out heat is this normal in winter.:coffee:
  3. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,185
    Aug 20, 2009
    If you're idling, it shouldn't take that long. Check your coolant levels.
    If you're driving, you may need a winter front.
    bullhaulerswife Thanks this.
  4. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
  5. Gambi80
    Gambi80 Medium Load Member
    That's a looooooooooooooong time. If I have mine plugged in, I have heat in less than a minute. If not, about 5-10 min.
  6. turnanburn
    turnanburn Medium Load Member
    628
    270
    Jan 25, 2011
    central Vermont
    Thermostat(s) or crud build up
  7. VisionLogistics
    VisionLogistics Road Train Member
    1,551
    978
    Dec 8, 2011
    Jellystone
    Same deal here. 2004 KW T2000 / Cummins ISX 475. Good coolant levels, PM'ed monthly, but takes 30+ minutes to give me any heat on recent cold mornings (-5 degrees, truck plugged in). I reckon it's just the thermostat stuck open. Once I drive it for 10 minutes it gets up to normal range. :biggrin_2552:
  8. Hanadarko
    Hanadarko Independent Owner/Operator
    2,971
    935
    Oct 1, 2009
    Midwest
    1999 KW W900L Detroit..
    New thermostats, winter front and full of LL coolant.
    At least 20-25 mins idling before I get any useful heat when the temp is 25 or below.
    ...however, once the heat starts - it gets to be a sauna in there. I almost have to shut it off.
  9. apyles
    apyles Medium Load Member
    449
    142
    Oct 21, 2011
    Newbern,Tn
    My 05 ISx, and all of our late 90,, model cummins and detriot's take at least 30 plus minutes to warm up, enough to blow any heat. Even if they are plugged up.
  10. Hanadarko
    2,971
    935
    Oct 1, 2009
    Midwest
    I think 12 gallons of coolant takes time to warm up!
  11. VisionLogistics
    1,551
    978
    Dec 8, 2011
    Jellystone
    Sounds like a job for a webasto coolant pre-heater!
