How many amps?
Discussion in 'CB Radio Forum' started by J Rich, Mar 1, 2019.
  1. J Rich
    J Rich Medium Load Member
    363
    380
    May 28, 2018
    Atlanta Ga
    Need to know many amps the Galaxy 47hp draws. I'm adding a quick disconnect to the power wires. The QD that I ordered has a 50 amp rating. If I remember correctly the Galaxy has 2 10 or 20 amp fuses, so I should be fine. But, I can't get to them very easy. The radio does put out 125 watts, but that's not amps.
  3. Ridgeline
    22,726
    123,425
    Put in a 20 amp fuse, it draws 15 amps at peak power, 8 amps dead key if I remember right.
    rabbiporkchop and J Rich Thank this.
  4. shogun
    shogun Road Train Member
    6,075
    72,163
    Jan 23, 2009
    Doing a regen
    I have a Connex 4600 with two 2290 transistors. It’s peaking around 135 watts, and my amp clamp shows a max of 17 amps draw.
    J Rich Thanks this.
