How many does it take to change a light bulb ?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Commuter69, Jan 10, 2024.
  1. Commuter69
    Commuter69 Road Train Member
    1,142
    635
    Jul 2, 2014
    OK, wrong question.....
    I have a 2017 International, and I'm fed up with how dim the headlights are.
    Are the headlights a sealed assembly or can someone with basic knowledge change the bulbs as needed(a video link would help)?
    What type of bulbs do I need? Any recommendations?
    NightWind Thanks this.
  3. NightWind
    NightWind Road Train Member
    2,718
    19,173
    Nov 11, 2006
    Sunny South, AL
    I have no experience with Internationals but from what I recall they are similar to the Mack I had. If in fact that is correct then you can change the bulbs or upgrade to an LED assembly yourself as I did on my Mack.
  4. 062
    062 Road Train Member
    6,335
    33,976
    Oct 20, 2013
    Are they Led or halogen?
    Led is most likely a sealed unit.
  5. Commuter69
    1,142
    635
    Jul 2, 2014
    IDK...
    Is there an easy way to figure it out?
  6. NightWind
    2,718
    19,173
    Nov 11, 2006
    Sunny South, AL
    Call the dealer, give them the VIN they will tell you, ask for parts number, google parts number, order what you need, watch YouTube how to, install, be happy!
    gentleroger and cuzzin it Thank this.
  7. 201
    201 Road Train Member
    12,797
    26,336
    Apr 16, 2014
    high plains colorado
    Is the plastic hazing? Some of those kits work for a while.
  8. Commuter69
    1,142
    635
    Jul 2, 2014
    I tried that first. No change.
    I'm assuming headlights are NOT LED, they are WAY too dim.....
    201 Thanks this.
  9. JB7
    JB7 Road Train Member
    1,029
    1,818
    Dec 13, 2022
    Laurel, MD
    Sylvania Home (sylvania-automotive.com)
    On the website you can select your vehicle and see what headlights are available. The brighter the bulb the shorter the life. And don't touch the actual bulb, best to wear latex gloves. Oil from your skin will cause the bulb to burn out very quickly. Lights do get dimmer over time. I would also check and clean any grounds for the headlights, probably along the frame rail next to the engine. Follow the harness from the headlight.
    Walmart sells a lot of bulbs at excellent prices in the automotive section if your truck has that type.
    HOW TO CHANGE YOUR HEADLIGHTS ON A INTERNATIONAL PRO-STAR - Bing video
  10. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    you can try adding a direct 12 volts to the bulb to see if it brightens up. or do a voltage drop. 2019 RH led assembly is probly over $1k each. you can add driving lights for way cheaper. i use aluminum polish on my old lights.
  11. Commuter69
    1,142
    635
    Jul 2, 2014
    I don't think mine are LED, they are too dim... and it's a 2017. When did they start using LED bulbs as OEM?
