How often do you lube?
Discussion in 'Ask An Owner Operator' started by Wespipes, Jun 7, 2020.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    so I have been doing it every 12k miles. As I change all my filters every 12k miles. Not oil. I have oil bypass system. So I change my oil when the lab test says it needs it, aroind 80k miles. But I've been thinking about doing it every weekend? I mean it can't hurt it right? I bought one of those dewalt powered grease guns to make the job easier. Thoughts?
    D.Tibbitt Thanks this.
  3. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    Mine only get it every 20k but if I was an owner op with one truck I would probably do every other week. So, 5000 to 6000 miles. I don’t see any benefit to more then that.
  4. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
    It’s not going to hurt anything. You’ll just have to watch out for excess grease. I use a old trigger style gun,it makes it easy to feel when a joint is getting full.
    Rideandrepair, PE_T, Wespipes and 2 others Thank this.
  5. abyliks
    abyliks Road Train Member
    4,121
    9,709
    May 2, 2010
    ludlow MA
    Usually once a month, unless I decide to be productive and actually do some driving then I will do it after 3 weeks, Usually only do ~1500 miles a week
  6. 650cat425
    650cat425 Road Train Member
    1,548
    11,043
    Jan 26, 2020
    Pennsyltucky
    Same... but I'm ~600 miles a week. I can say I've never had a lubrication related failure though.
    Rideandrepair and Wespipes Thank this.
  7. DUNE-T
    DUNE-T Road Train Member
    7,046
    17,162
    May 10, 2015
    Detroit, MI
    Every oil change at 12k miles
    Rideandrepair, bzinger and Wespipes Thank this.
  8. Chris M.
    Chris M. Light Load Member
    123
    87
    May 27, 2010
    Tater State
    My maintenance varies. I try to lube the truck and trailer every month, I try to do u joints every two weeks, oil changes are 12k miles.
    Rideandrepair Thanks this.
  9. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    What type of grease do you use and do you use different types for different parts?
  10. Chris M.
    123
    87
    May 27, 2010
    Tater State
    Lucas Red n Tacky. Youtube Project Farm, he breaks down cheap grease to the expensive in one of his videos.
    Tug Toy, JonJon78, 650cat425 and 3 others Thank this.
  11. AModelCat
    164,678
    Greased the old man's trucks top to bottom every weekend. Driveline mid-week. By the time you factor in a new inter-axle shaft, ABS valve, airbags, yokes, labour and downtime you could easily buy enough grease to last a few years.
