How often should you replace your Nox Sensors
Discussion in 'Volvo Forum' started by Rob100100, Oct 19, 2019.
  1. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    The first set of nox sensors(factory)lasted for 4 years, then they went in a really bad spot in Montana a long way from a volvo dealership. It is coming up to 4 years since the replacement and the start of winter. So thinking of replacing them in November at the next oil change/pm. Was the first set just unlucky or is 4 years about the lifetime for them? Opinions or experience appreciated. Thanks in advance.
    Intothesunset Thanks this.
  3. Carlinho
    Carlinho Bobtail Member
    28
    39
    Mar 2, 2018
    Harker Heights, Texas
    I got about 530k out of the front one by the turbo.
    KB3MMX, Rob100100 and Intothesunset Thank this.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,514
    Dec 29, 2008
    Northridge, CA
    when codes pop up...
    KB3MMX Thanks this.
  5. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    Replace them when the code pops up.. No reason to replace them before as they aren't Cheap and won't shut you down...
    KB3MMX, AModelCat and buddyd157 Thank this.
  6. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    They will shut you down at 5mph i usually try to replace mine every 3 years or so just so i can avoid the derates.
    KB3MMX and Rob100100 Thank this.
  7. TruckerPete1990
    8,623
    5,377
    Jul 16, 2012
    5 MPH must be a Volvo thing then. I've had my inlet go out and never derated me. My outlet is bad right now and hasn't
  8. Rob100100
    206
    122
    Mar 5, 2016
    Thanks Nasriza for your info. That is what happened in Montana near Helena, Dealership in Great Falls was closed with Calgary being the closest one that was open. Cost me 3 days by the time all was done. I know you said 3 years but I will have them replaced at the next oil change. Costs money but so did sitting in Calgary. I prefer to replace items before the code comes up if possible.
  9. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    usually its about 1300 for both to put in new onces by the time i paid for tow down time and volvo dealer charge i was in about 3600 so this way its a no brainer i do it a little more often but i never get a call from a driver telling me truck is derated.
  10. Rob100100
    206
    122
    Mar 5, 2016
    I disconnected the speed sensor just to get me to Calgary. As you said expensive to replace the sensors but worth it to do before you get a code and a derate.Thanks again for the help
