How Often to Drain/Flush Coolant?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Dec 9, 2018.
  1. PE_T
    PE_T Road Train Member
    Is a flush really needed in today’s trucks? My truck has a coolant filter that I replace at 100k by the manual. I have a 2014 Freightliner Cascadia.
  3. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    You can send in a sample just like with oil analysis. Change it when they tell you to
    PE_T Thanks this.
  4. Brandt
    Brandt Road Train Member
    4,624
    6,359
    Sep 17, 2012
    If you use the red extended life coolant. That stuff is good for like 400,000 miles. Just don't mix with regular coolant. I see some guys just adding water. That a little crazy. If you want the engine to last a long time
    Nothereoften and PE_T Thank this.
  5. Rideandrepair
    17,556
    56,881
    Aug 8, 2015
    Antifreeze never goes bad. The additives do dissipate over time. Using a filter w/ dca time release is supposed to replenish system while keeping it clean. I would still check dca levels though as the filter only releases additives as needed due to a thin metal corroding in filter before releasing additivesI As far as flushing goes it’s always a good idea. I think doing new hoses at least every 5 yrs at most and flushing and refilling with new antifreeze is worth it . The more you flush the longer radiator lasts.
  6. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The steel coolant tubes are bad to rust thru if your truck still has the factory ones on it?
    Rideandrepair and PE_T Thank this.
  7. PE_T
    I am not sure what you are refering to. My truck has a plastic coolant reservoir.
    Rideandrepair Thanks this.
  8. sbaumann14
    sbaumann14 Road Train Member
    1,236
    1,431
    Sep 1, 2010
    Rhinelander, WI
    Yes...replace steel tubes with stainless at first sign of rust
    PE_T and Rideandrepair Thank this.
  9. Rideandrepair
    17,556
    56,881
    Aug 8, 2015
    He means the big steel tubes that connect with upper and lower hoses they rust out and can be replaced if so by SS tubes.
    PE_T Thanks this.
