How to Actually Diagnose Aftertreatment problems?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by revzilla, Aug 28, 2024.
  1. revzilla
    revzilla Bobtail Member
    29
    15
    Jun 13, 2023
    I've got a 2011 volvo vnl in derate. Message says "analyzing def quality 5mph derate removed". It's my understanding that anything that could cause high outlet nox could cause this? So if I change the def and clean the dpf filter and it's still got the message it's going to need a scr?
    Also as a side note I've attempted forced regen and dpf temps are only around 700 degrees. But also the duty cycle on the 7th injector is very low 7% or so. I would think the ecu would command more duty cycle out of the 7th injector to get it up to temp. The dpf soot ratio is 58% so maybe it does that because it doesn't really need a regen?
    Any help appreciated
  3. 062
    062 Road Train Member
    6,332
    33,972
    Oct 20, 2013
  4. revzilla
    29
    15
    Jun 13, 2023
    Here is some more info if that is helpful on the regen, looked like it was only around 3 psi during. Wondered if that is normal for the d13? Assuming the temp needs to be higher that for a successful regen?
  5. 86scotty
    86scotty Road Train Member
    4,710
    12,929
    Aug 27, 2017
    Appalachia
    2011? Sell it and buy a newer or older one. Up to 08 or 13 or newer.
    That is my serious advice, not kidding.
  6. revzilla
    29
    15
    Jun 13, 2023
    haha not the advice I was hoping for but you might be right.
  7. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Not enough diesel those temps should be t2 and t3 880 900 at the middle to end of regen check 7 Th injector if clogged or also check the t on top working properly didn’t seem like spraying enough fuel maybe exhaust leak at bellows and fuel is coming out
    062 and revzilla Thank this.
  8. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Also intake manifold psi seems low usually should be around 9-12 psi during first part of regen
  9. revzilla
    29
    15
    Jun 13, 2023
    Hmm yeah I did take 7th injector out and tried to clean it with ultrasonic cleaner didn't seem like it was spraying like a normal injector would. Probably should just replace it. When I was checking the def doser I did change the gaskets of the flex pipe between dpf and scr (bellows) and still got those temps.
    Doesn't seem to have any obvious boost leaks but should check that if it that far off. Turbo didn't seem to have much shaft play so I figured it was ok but maybe the turbo actuator could be failing? Its has only been running 25psi max loaded but I thought that was because of the derate.
    I still don't understand why the 7th injector is not commanding more duty cycle though. Makes me wonder why the ecu not command 100% duty cycle on the 7th injector if it needs more heat. Almost seems like possibly a software problem potentially too not sure if a ecu update would fix mine. But I've read in another thread an update fixed theirs but they had a slightly different problem than me.
    Also does anyone know if PTT 2.8 can exit inducement (derate) on my generation of Volvo let me know. PTT 1.12 can't I don't think
  10. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Yes ptt 2.8 can exit inducement all your numbers look good change the gasket and the cooling for the 7 th injector and test regen one more time and see what temps come up to
  11. revzilla
    29
    15
    Jun 13, 2023
    Sounds good-Also does anyone know what ppm nox outlet should be idling- or pulling a load? Like at what ppm would a derate happen if anyone knows
