How To Clean Your Dishwasher Filter
Discussion in 'Other News' started by Chinatown, Nov 24, 2021.
  1. Chinatown
    Chinatown Road Train Member
    77,847
    184,928
    Aug 28, 2011
    Henderson, NV & Orient
    Step 1: Fill a mixing bowl with hot water and dish soap.
    Step 2: Remove the lower dishwasher rack or roll out of the way.
    Step 3: Most cylindrical filters are located at the floor of the dishwasher and are removed by twist-lock. Look for arrows indicating which way to twist. Twist, unlock, and lift out. If a flat filter, it can often be easily lifted out. Repeat with top filter or any additional filter, if applicable.
    Step 4: Place filter (or filters) into the mixing bowl with cleaning solution. Soak for five minutes. This will help loosen debris.
    Step 5: Using a dish-washing bristle brush or an old toothbrush, scrub away debris and gunk from filter.
    Step 6: Rinse thoroughly with hot water.
    Step 7: Using a sponge or dish rag with hot water and soap, wipe down the opening inside the dishwasher where the filter was removed to get rid of any loose debris.
    Step 8: Replace filters in the dishwasher.
    If you're a visual learner, this TikTok cleaning video demonstrates the process. If you're unable to easily find or remove your dishwasher filter, consult the dishwasher manual before beginning.
    Now that your dishwasher is in order, check out these 12 Surprising Things You Can Put In Your Dishwasher.
    Read the original article on Southern Living
    bzinger Thanks this.
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    hey bud. Have you been drinking a little tonight?
  4. buzzarddriver
    3,836
    11,606
    Feb 1, 2011
    Dallas, TX
    Where is the article that teaches millennials the 10 steps to boiling water?
  5. jamespmack
    216,640
    Don't use gas.
    bzinger, cke, mjd4277 and 2 others Thank this.
