How to figure weight distribution?
Discussion in 'Flatbed Trucking Forum' started by leadfoot80, Jul 18, 2013.
  1. leadfoot80
    leadfoot80 Light Load Member
    199
    34
    Feb 17, 2012
    S.E. WY
    To you experienced flatbedders out there who haul a lot of palletized sack material: how do you figure out what to put where (when the pallets are all different weights -- for instance, 7 pallets that weight 4k lbs each, 2 that weigh 2500, 3 that are about 2000, etc.)? I've recently been running a lot more loads that require me to go through the port, and I'm getting ulcers from stressing about if my axle weight is gonna be legal! I really don't want to have to pay $10 every load just to run over the Cat scales..
    Any tips?
    Leadfoot
  3. xTHANATOPSISx
    xTHANATOPSISx Light Load Member
    77
    32
    Feb 12, 2010
    Hutchinson, KS
    Center the heaviest skids and work each way will usually work. If you are pulling a spead its pretty easy since you can play a little bit heavier to the rear.
    If you have multiple drops then you'll have to look at it a little and you might need to put say your 2nd or 3rd drop ahead of your first to balance if the weights are real screwy.
    If you get a fairly evenly spread load that puts you at gross, scale it to see how you balanced and make a note on the ticket. Keep it around and use it to remind you where it stopped and started and let that help you to work it out.
    A flat will balance a lot like a van with the same axle setup so think about how van loads get put on with singles and doubles to spread enough weight back and then kinda figure how much you can move the start back if you load it all doubled.
    Mistakes happen to the best of us and only the knowledge from scaling loads now will be available later to let you load from memory later. You can't always know how every load will balance on different trailers so other's information is only a guideline.
    leadfoot80 and SHC Thank this.
  4. Nicaraguense
    Nicaraguense Light Load Member
    68
    42
    Jul 1, 2012
    When in doubt, scale it out. If the equipment is your own or the company is willing, get some scales put on the truck and trailer. Every trailer and truck is a tad different, but like already mentioned, if possible have the heavier stuff centered, and work your way out. If not you can also try figuring how much the pallets on the front half add up to versus the rear half. Thats not very accurate though, and that raises the last issue. Even if you are an expert at always spreading out the weight properly, if you are hauling near gross weight, you run the very real risk of being overloaded. They may say each pallet is 5000 when in reality it may be 5100 or 5200 or maybe 3000.. you never know. 100 lbs per pallet/bundle adds up. And you get to pay the ticket. Load scales are around 200-500 each.. or keep paying the 10 buck per trip, either way will be less than the over weight ticket you risk getting.
    SHC and leadfoot80 Thank this.
  5. leadfoot80
    199
    34
    Feb 17, 2012
    S.E. WY
    The only thing that makes me nervous about loading the heaviest in the center is that this trailer I have seems to be just about worn out. It's a 48' Dorsey, the axles are only about four feet apart, and even when it's empty, it has no 'bow' to it. When it's fully loaded, it sags a bit. I've heard stories about flatbeds snapping in half, and though I don't know how probable that is, I don't want to take that chance. So I tend to load my heaviest to the ends, with a little more to the rear (for instance, on the load I mentioned in the original post, I put 3 of the 4k pallets at the front, then the 2k-2500 lb pallets in the center, then the remaining 4 4k lb pallets at the rear. I didn't run it over the Cat scales, and the POE was closed when I went by, so I counted myself lucky today. But it got me wondering about how other drivers figure where to put their weight.
    Thanks for the input!!
    Leadfoot
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    not all trailers bow up. some are just flat out flat.
    i load a lot of small loads that are full gross. in the middle. specially if it's tarped. why roll out 2 tarps if you don't have too. AND deal with all that excess tarp.
    this step i'm pulling now. has a decal at the exact location the manufacture wants you to load that ONE coil that's full gross. and it's right smack in the middle.
    having only a 4 foot spread kinda sucks. according to the atlas you limited to 34 untill your spread hits 8 feet. then you get 38 on the rears.
    in other words. anything under 8 feet is considered a tandem axle.
    leadfoot80 Thanks this.
  7. dirtyrabbit
    dirtyrabbit Medium Load Member
    416
    158
    Jun 19, 2011
    KS
    Snowwy is right on, if you got a 4' spread you don't have a spread per DOT. So now your weight distribution is even more important. Start in the middle and work it out. If your worried about the trailer breaking, you should be under there looking for small cracks. That will show up long before it collapses, or take it to a shop and have them do a NDI inspection.
    Good Luck Driver!
  8. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    If you don't have air gauges get some.
  9. okiedokie
    okiedokie Road Train Member
    14,037
    111,684
    Jun 13, 2011
    PNWET
    There is a cheap way to put scales on a truck. Hanging a short chain from the frame by the axle. I'm on a ph so maybe someone else can go into detail.
  10. fisher guy
    fisher guy Road Train Member
    1,993
    1,061
    Mar 22, 2009
    Ocala Florida
    air guages seem to be the most accurate in my opinion on flat level ground if my tractor guage say 70it means i have 31k even on the drives if i had a trailer guage i dont think i would ever need another cat scale
  11. leadfoot80
    199
    34
    Feb 17, 2012
    S.E. WY
    I would love to hear more about this.
    I have an air gauge in the tractor, but I haven't figured out what equals what yet. No gauge on the trailer (spring suspension).
    Unfortunately it's not my truck/trailer .. or rather, fortunately it's not. If it was I believe I'd drive it off a cliff. :biggrin_255:
