First thought was the intercooler so I pressure tested it and it is good along with all the boots from turbo to intake manifold.
Any ideas on how to diagnose this? Its only a minor leak right now, it comes and goes throughout the day. Sounds like a high pitch squealing when I pull a hill. I'm sure a smoke test wouldn't work in this case and there's no way building that much boost while sitting is possible. I am out of ideas
Probably should add this is a 98 Volvo with 12.7 Detroit
how to find boost leak
Discussion in 'Volvo Forum' started by Terry270, May 6, 2015.
nevermind just re read your post if smoke test won't work my idea probably won't either
It's probably a small crack in the exhaust manifold right in the middle of the Y
Sometimes a boost leak at the inlet of air compressor can generate noise like this .
Ben -
why you think you have boost leak ? the turbo is new ?
OK I'll Check it closely for cracks thanks
Near the inlet of air compressor? Can you explain? This problem is def related to turbo boost as I can only make it happen with a trailer behind it and getting into boost on a hill. And even then its sporadicLast edited: May 7, 2015
Turbo is a somewhat newer BW 171702 and judging by the way the truck pulls hills I believe there's nothing wrong with it but who knows
Maybe one of the hoses in the boost path has a small crack or pinhole.
Those got tested with the intercooler and are good.
This is what my crack looked like. (That didn't sound right)
It made all different noises until I found it. A pinging noise, a knocking noise and a whistle
