How To Insert Image Into Signature
Discussion in 'Truck Forum Information Center' started by WiseOne, May 8, 2007.
  1. WiseOne
    WiseOne Inactive contact bullhaulerswife
    2,613
    1,225
    Feb 8, 2004
    Truckers Report, TN
    Go into your UserCP, click on edit signature, once in there, in the editor you will see this icon:
    Click on that icon and insert the URL where the image is hosted (has to be hosted somewhere) at like if the image is a sparkly like this one at this URL:
    http://img.photobucket.com/albums/v224/Y2kbug2000/daxter29ye.png that is what you enter into that pop up prompt.
    Wherever you go to find the image you want to insert it is ALWAYS the URL AFTER (find): img src= http://www.whateverxxxxxxxx.com/images/cool.jpg
    It will create the actual code for you such as:
    PHP:
    [IMG]http://i103.photobucket.com/albums/m146/Nlee49203/293772ct0pf08klc.gif[/IMG]
    Which would show up in your signature like this:
    IF you upload your OWN pic to THIS site, remember to click to the right of the uploaded picture: Insert Signature Picture
  3. whispers65233
    whispers65233 Medium Load Member
    654
    18
    Mar 3, 2006
    Boonville, MO
    Wiseone.....after your help and Cyubergal's as you can see I got the image to work in my signature. Can you tell me how to add a glitter image or an animated one? Thanks:yes2557:
  4. Cybergal
    Cybergal Road Train Member
    6,272
    2,399
    Oct 20, 2008
    YOU do the animated and glitter ones' I do believe the same way... with the
  5. Baack
    Baack Road Train Member
    15,294
    10,174
    May 24, 2007
    Wisconsin
    I found a hosted picture that I want to use on msm. I cut and pasted it into front page and got the code. for the picture. The problem I get is this
    Upload of file failed.
    So I saved it to my pictures and tried it that way. The thumb nail comes up but when I go to save the picture I get the message I listed above.
  6. Baack
    15,294
    10,174
    May 24, 2007
    Wisconsin
    Thanks Cybergal I finally figured it out
  7. MXH
    MXH Light Load Member
    101
    6
    Jan 28, 2006
    Where's that icon? The photobucket image doesn't exist. And when I get the code where does it go? I can upload a pic, and it displays in the user CP, but not on any posts.
    This seems to raise more questions than it answers.
  8. WiseOne
    2,613
    1,225
    Feb 8, 2004
    Truckers Report, TN
    They must've removed the photobucket pic, I will fix now. Do you have, in UserCP, Edit Options, Show Signatures checked? Also, once you change it, all the older posts where you didn't click on show signature might not show up...
  9. MXH
    101
    6
    Jan 28, 2006
    ok I've got show signature checked.
    I go user cp, then edit signature, then I do not see the icon anywhere.
    What's more, if I upload an image from my hard drive, it will be shown in the User CP-edit signature section, but it will not show up in any posts.
  10. WiseOne
    2,613
    1,225
    Feb 8, 2004
    Truckers Report, TN
    I did it for you. AFTER you upload the pic and you see it, on the right it has a link: Insert Signature Picture. You forgot to click on that link to actually insert it into the signature...
  11. MXH
    101
    6
    Jan 28, 2006
    THanks. And Chaka thanks you too!
