how to remove power fuse panel
Discussion in 'Kenworth Forum' started by ptours93, Sep 27, 2011.
  1. ptours93
    ptours93 Bobtail Member
    37
    4
    Sep 12, 2011
    orland park il
    i did the search and nothing,i can't remove fuse panel cover. is there a trick for this.i have issues behind this panel.for some reason i've lost 3 circuits all pointing to fuse box.
  3. ptours93
    37
    4
    Sep 12, 2011
    orland park il
    i should of detailed this a little better. i'm trying to remove the actual fuse panel that has all of the cb/fuse componets to get behind it and check these power wires.
  4. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Buy yourself a little circuit tester or DVOM and test it from the fuse side. Much easier.
    If you lost multiple things, it's most likely a plug in connector on the wiring harness. Very seldom do you have fuse block problems. If you did, you would see signs like plastic that got hot, etc.
    What have you lost?
  5. ptours93
    37
    4
    Sep 12, 2011
    orland park il
    jake, marker lites.
  6. drwye
    drwye Bobtail Member
    7
    4
    Aug 27, 2011
    KingsvilleON
    The panel comes out after the power distribution box is removed from firewall. Takes about a hour. Once you get the windshield washer bottle mount and air intake pipe out of your way you can see how it is held to the firewall. You can order all the wire connectors from KW to fix rotted off ends. don't forget to pull panel left of dash there are 4 plugs there you can't see from below dash. With some skill and patience you can save a lot of money on this job.
    ptours93 Thanks this.
  7. j_anderson561
    j_anderson561 Bobtail Member
    Hey I removed box from fire wall.. all wire harness plugs.. still coudnt get fuse panel off to see behind it.. is there a step I missed
  8. Inderjit
    Inderjit Heavy Load Member
    774
    740
    Sep 17, 2017
    There should be some screws on the fuse/relay side that have to come out then there are two plugs on the outside with latches or barbs you push in and a round power plug that have to be pushed into the box then the works comes out.
