how to replace coax cable on wilson 1000 antenna
Discussion in 'CB Radio Forum' started by the buzzsaw kid, May 3, 2010.
  1. the buzzsaw kid
    the buzzsaw kid Bobtail Member
    24
    Apr 20, 2010
    Greenville, WI
    i found that my coax cable on my wilson 1000 antenna has been shorting out and want to know how to replace it from the antenna
  3. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    If it's Mag Mount. It's easy. Unscrew the Nut on top. Raise cover up. Then look at the bottom of Mag. In the center is soft. Cut a hole in it. Then use a wrench to loosen it. And you will see how to remove coax. Or you can go to the Wilson web site for more info.
    the buzzsaw kid Thanks this.
  4. TimberDrives
    TimberDrives Bobtail Member
    Any place close to Cedar Falls, IA to get a CB installed?
  5. Mad Dog 20/20
    Mad Dog 20/20 Heavy Load Member
    768
    193
    Jan 31, 2010
    Skid Row
    If you can't find a CB shop ask at a car audio shop.
  6. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    LOL forget asking a car stereo shop, they don't know jack about CB's.
    Hooking up and setting up a CB is so easy a caveman could do it. I suggest you learn how to do it yourself.
    Skunk_Truck_2590 Thanks this.
  7. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    Really. No one has to be an eletrician to install a CB. Basic wiring. :biggrin_2556:
  8. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    If is a mag mount,
    just remove the felt covering on the bottom of the the base and you will see how to replace it. Just be sure that you use the same length of coax and don't use some cheap ### truck stop crap. You may have to do a little soldering but as long as you solder the center conductor and the shield in the same place that the factory had it then you will be fine.
  9. Carolina Thunder
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    Red wire goes to hot(positive side of your battery) black wire goes to ground (black wire to the negative side of your battery) for power. Antenna should have an SWR of less than 2.0,a perfect 1.1 match is a wast of time and will gain you NOTHING in the performance of your CB radio regardless of what people tell you! Use a good mag mount antenna such as Wilson or a good trucker still antenna such as Wilson or predator and also the best coax you can find.
    If you want some kind of custom install then for sure go to a custom stereo shop,the will put if where ever you want it.
