How to rewire/remove replace wires on bulkhead passthrough?
Discussion in 'Volvo Forum' started by Joeziah, Jun 24, 2023.
  1. Joeziah
    Joeziah Light Load Member
    176
    131
    Jan 2, 2016
    Might be a dumb question but, how does one remove or replace a wire on the passthrough engine side? Do I need to remove a cover if so how? Do I just need a pin removal tool and punch it down there and pull the pin out?
    Don't want to go banging or disassembling stuff and couldn't find a video of anyone doing anything on that firewall.
  3. AModelCat
    164,667
    Remove the plug and post some better pictures. Thinking the lock for the pin is on the part of the plug that is in the receptacle.
  4. Burdisco
    Burdisco Light Load Member
    119
    53
    Apr 25, 2015
    10 mm nut and bolt, the nut is captive in the engine side. Access the bolt from drivers foot well and with 1/4 drive 10 mm on a extension undue the bolt. The Canadian dealers sell the male and female pins. Alternatively cut wires ,push out the rubber plugs and run a new gang plug for the one wire.
