How to stop car bounce when using tire strap
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by MrBill103, Aug 25, 2015.
  1. MrBill103
    MrBill103 Light Load Member
    94
    56
    Jul 27, 2015
    Central PA
    I have a chain trailer but use ratchet over tire straps often and last week had some minor damage due to PA's wonderful rough roads and not having the car chained. How do you guys who have strap trailers get your height down and avoid the bounce? I have been hauling cars since 1992 in one form or another so I know the answer is you don't stop the bounce, so I guess I am asking how you stay under '14 without having the top rack too close to bottom cars? Thanks in advance for answers/ideas
  3. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    Good question, we only run a 4 car so I only have that issue in one position, but when we had our 8 car is was a problem.
    Do you have drop pockets in your lower deck already? That 2" can be life or death, but I know you know that.
    Hammer166 Thanks this.
  4. MrBill103
    94
    56
    Jul 27, 2015
    Central PA
    The truck I drive does but our 9 cars don't
  5. KANSAS TRANSIT
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    I would say either get pockets installed or just chain down the cars in the problem areas? Lots of places outlawing chains though, at least on the OEM side.
  6. Tropsnart
    Tropsnart Road Train Member
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
    With straps on the cars should generally bounce downward. I think most with strap trucks run just as tight as we did with chain trucks. The new Cottrell trucks have pockets, articulating decks and a very good design that allows almost everything to fit that would with chains. I have however used the straps hooked to the frame on occasion just like you would chain a car. Surprisingly, the one over the hood will squat down easier with straps in the frame than with chains. Sounds like you'd be asking for trouble but I haven't had any problems doing it.
  7. Tropsnart
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
  8. KANSAS TRANSIT
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    Although I can appreciate you innovation (I have hauled some crates with auto haul straps linked together) the J hooks on my straps are pretty thick and probably wont fit into many/any tie down tees or slots, maybe on a pickup?
  9. Banker
    Banker Road Train Member
    4,611
    15,461
    Aug 19, 2012
    How did your damage occur? In my experience a unit only bounces down or front to back. But if all units are strapped they will bounce front to back in sequence with the unit next to it and won't bump each other. If you had one hard tied too close to one strapped they could bump into one another. As far as getting height down 19.5 tires allow me to haul 6 full size 4x4's and still get 13'6 or so, when I load it correctly.
  10. Tropsnart
    1,130
    2,386
    Jun 8, 2015
    Pavilion New York
    The j hooks on the new Cottrell trailers are about the same as an S hook on a chain setup. I have older hand ratchet straps that won't fit in the slots, but mostly I do it on trucks and bigger suvs.
    KANSAS TRANSIT Thanks this.
  11. Terry270
    Terry270 Road Train Member
    1,455
    1,678
    Jan 21, 2014
    BG, KY
    Heres an idea I had but haven't tried yet: http://www.autohaulersupply.com/cat...21---blue-axle-strap---3335--lbs-wll-4157.php
    Take one of those and wrap it around subframe or something sturdy and hook your chain to it and squat the suspension. If you don't have a chain trailer you could use a ratchet strap.
