How to warm up the engine block?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by DUNE-T, Dec 29, 2017.
  1. DUNE-T
    DUNE-T Road Train Member
    7,069
    17,234
    May 10, 2015
    Detroit, MI
    The truck does not have a built in 110v block heater. What can be done to warm up the block for an easier start in this cold weather?
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Old school..... lay a pan of charcoal under oilpan and hang a tarp around truck to keep the wind from blowing the heat away.
  4. DUNE-T
    7,069
    17,234
    May 10, 2015
    Detroit, MI
    Lol was trying to avoid that
  5. Animosus
    Animosus Heavy Load Member
    736
    2,936
    Dec 7, 2015
    SE Wyoming
    Get a block heater then?
  6. Superhauler
    12,209
    100,735
    Jan 30, 2010
    keep stroking.
    Get a torpedo heater and hang a tarp around the truck. Just be careful it don't melt something.
    Hurricane69, SAR, Oxbow and 2 others Thank this.
  7. DUNE-T
    7,069
    17,234
    May 10, 2015
    Detroit, MI
    I might have to, it's just not fun installing it in 5 degree weather. I was thinking maybe installing coolant heater will.be easier?
  8. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Is it your truck and do you have power where the truck is parked?
  9. DUNE-T
    7,069
    17,234
    May 10, 2015
    Detroit, MI
    Yes and yes
  10. kemosabi49
    11,011
    48,101
    Jan 13, 2013
    SW Arkansas
    Espar make a diesel fired coolant heater
  11. special-k
    1,523
    3,258
    Dec 27, 2008
    You can put a 110v block heater into the actual block or you can get one that goes into the heater hose and heats the antifreeze. They can be 110v also.I think the type that goes in the block are cheaper. Both can be installed with hand tools outside if you need too.
    AModelCat Thanks this.
