How???
Discussion in 'May Trucking' started by Dozzer6, Jan 13, 2012.
  1. Efon
    Efon Road Train Member
    1,080
    286
    Jan 6, 2009
    Fort Collins, CO
    Or, just tell your dm in the morning you are over gross and are not moving. They will either have the shop siphon off fuel or take the load off you.
  3. Dozzer6
    Dozzer6 Light Load Member
    252
    22
    Jun 30, 2011
    Vancouver, Washington
    Efon, I have idled off three gallons, but hearing you say syphon... I was going to suggest to night dispatch that the shop syphon out the reefer since it is not being used. That would give me the breathing room I need. And yes I am worried. Mainly because I am an anal by the book kind of guy. I don't even like to bend the rules. I'm weird like that for some reason, but only on certain things. Like things that can get me into teouble with the badge wearing kind.
    Dozzer
  4. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,979
    Apr 19, 2011
    Loaded at C&H awhile back.
    Was greenlighted by Fairfield scale. Thought to myself "I'm good". Was redlighted at Cottonwood. I was 1200 lbs over on tandems. Good on gross. Only problem was I couldn't slide tandems back because I was right at 40' bridge law.
    So, I called for permission to break seal and I offloaded almost 60 cases of sugar into my bunk ;-)
    CHP didn't write me up or anything, plus I needed the exercise ;-)
  5. Dozzer6
    252
    22
    Jun 30, 2011
    Hmmm, 60 cases of beer in my bunk. I'm feeling thirsty.
  6. Scooter Jones
    9,551
    19,979
    Apr 19, 2011
    Exactly! I mean, beer is pretty much sugar ;-)
  7. Efon
    1,080
    286
    Jan 6, 2009
    Fort Collins, CO
    If dispatch tries to push you to run over gross, it doesn't matter what load it's on, tell them to send it over the Qualcomm that they want you to do that. Even then, don't do it. Just like when companies will try to push drivers to run illegal. It's your ###. Get it in a message instead of a phone call that cannot be traced.
  8. Dozzer6
    252
    22
    Jun 30, 2011
    Efon, that's what I did. All over Quallcomm. If I was dealing with my DM she would have flat out said that I'm not running even if it's only one pound over. We will see where it goes today. Most likely they will drain something to get it down.
    Dozzer
  9. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    Wow. I can't believe this is still an issue. If you drove for me, you would be out of a job right now. The chances of actually being harassed for a mere 50# overweight at any scale are slim to none, and even if you ARE hassled about it, the MAXIMUM fine is going to be less than what you are costing the company by refusing to drive. Fuel (and anything else you can drain from the truck) is expensive. Late loads can be expensive, too.
    Seriously. 50# is nothing to worry about. Until you exceed the 400# that a lot of states are granting with the APU exception, they won't even look hard enough at your truck to see if you've actually got an APU. It isn't worth it to them to write that ticket...the amount of the fine won't even be enough to pay the officer for his time showing up to court if you challenge the accuracy of his scales.
    Just run the #### load.
    48Packard Thanks this.
  10. rogueunh
    rogueunh Road Train Member
    1,086
    23,149
    Jan 4, 2011
    50 lbs??? No way, lol.
    You'd lose that much after being down the road about 50 miles.
    I agree with above. Can't believe this is an issue at all.
    (Maybe you should start the reefer unit as well to speed the process??? LOL)
  11. Joker85
    Joker85 Road Train Member
    1,465
    331
    Jul 3, 2010
    Phoenix Az
    if it was me, id roll, you're gonna burn it off, I've rolled 200lbs over gross and i was legal by The time I got to a scale, why don't u go to a cat scale, unless u like sitting not making any money by the time u get to the first scale you'll be legal
