HP vs Fuel Mileage
Discussion in 'Experienced Truckers' Advice' started by Palazon, Dec 10, 2010.
  1. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    Ok, we've all seen the "why is my rig getting poor MPG" questions. I'm curious to see what the more experienced truckers think.
    Do you think it is better to have a higher HP engine (475-515hp) with an experienced (responsible) driver or a lower HP engine? This assumes standard loads grossing out to 65-80k lbs.
    Now, I had a 500 hp 'shaker that when the load was under 50k in the box, I'd manage about 7-7.5 mpg. On my light (30k) pallet loads it got even better. Now I know the driving style does have a lot to do with it. This was WA state, easy take offs, cruising at 62mph and (trying to) slingshot or rollercoaster the hills. At 62 mph in 13th gear, the tach was about 1450. I used the cruise control alot. On the lower HP rigs (400-450) I'd only get 5's on mpg.
    So what is your experience? Does a higher HP engine get better mileage than a lower HP engine IF the driver is a responsible type? Or was that 500 hp rig a fluke?
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    This is kind of a trick question.
    When my motor was stock it got bad fuel mileage. Once I turned the fuel to it, it went up.
    With that being said, it also depends on the driver.
    Palazon Thanks this.
  4. lobes1985
    lobes1985 Medium Load Member
    306
    112
    Aug 9, 2009
    Wappingers Falls, NY
    Im gonna assume the shaker you had was powered by a detroit. They are known for getting better milage. Mine is a 515 detriot and I get about 5 with it but I run in the mountains of PA all the time and its geared lower and I run 72. In 8 over at 72 my rpms are about 1650-1700. I may have a 515hp but I get walked all over by the 475 cats even when they are heavier, but the cats do get worse milage then I do.
  5. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Of course! If you are an experienced driver with more power you will get better fuel mileage. Now this is true for the folks who travel 48 states. If you are just toodling around Florida then it probably won't work to your advantage. You burn up a lot of fuel spinning those low gears chuggin up the big hills. If your truck has more muscle to put behind the bigger gears then you can go up these hills without having to keep dropping little gears. The down fall is inexperienced drivers don't know how to shift or even why they are shifting! Also, they would burn up all their fuel trying to race everyone from light to light, basically using up fuel at the wrong times. The lowdown, experienced drivers can do very well with a little more hp. Overall for large companies though it is way more economical for them to run with no "balls".
    rocknroll81 and Palazon Thank this.
  6. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    I have a 600 cat and get 5.8 to 6.3 mpg with it runninmg the northeast at 80k with about 25% empty and i know guys with smaller hp Detroits,cats and Cummins that only get in the low 5s. Alot of it has to do with the way you drive,the way your truck is speced plus the area you haul not just the size of your motor. But for me i will take a big hp motor anyday over a small hp one. Its not hard to figure out a big hp motor will do better on fuel if speced and driven right just because it will turn less rpms to do the same job and pull a hill with less strain.
  7. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    I can understand progressive shifting in most situation's but I'm sorry your not going to progressive shift taking 6 months to get through a large intersection with a 10 second green light and a #### load of traffic.
  8. Krooser
    Krooser Road Train Member
    2,493
    1,066
    Jul 25, 2010
    Wisconsin
    My 3406E (435 HP) has a lifetime ECM mileage of 6.23.
    Last week, running two loads at over 50K in the box, I got right at 6.5. I just did a major on it in September.
    My son's 600 CAT in his 379 can get 6+ if he keeps his foot outta it... but his hired driver can't seem to understand that.
    The 12.7 Detroit in his 377 gets a steady 7.2 to 7.4 with him behind the wheel.
  9. Lonesome
    Lonesome Mr. Sarcasm
    11,718
    24,466
    Dec 15, 2007
    Northern Indiana
    I'll take horsepower, thank you. Less HP means my foot is goung to be in it a lot more.
    Also rear gearing has a lot to do with it.
  10. Palazon
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    I agree on the pumpkin gearing... the really good mileage rig was geared so I had to start one gear lower than the other rigs when heavy, but the RPM when at cruising speed were 150 lower. Note that I ran fat pigs, rarely under 50k in the box.
    My reasons for asking is that I'm starting a plan to own a rig someday. I plan to purchase a used rig from a dealer and lease back to a company rather than lease purchase from a company. This is about 3 years down the road.
    Thanks for the thoughts guys. I just wanted to see if the more experienced guys agreed with my thoughts on this HP issue.
  11. Powder Joints
    7,993
    8,415
    Sep 25, 2007
    Rosamond, SoCal
    The truck I drove with a Cat C15 set at 550 averaged 6.75 to 5.25 running 11 west same as now, the truck I currently drive has a 450 Detroit that only averages 5.75.
    Both 10 speeds.
