Hub oil leak
Discussion in 'Peterbilt Forum' started by Bernard D, Apr 2, 2021.
  1. Bernard D
    Bernard D Heavy Haul Member
    104
    27
    Jun 27, 2020
    • Have 03 pete. 379
    • 3.55 rears.
    • Always having leaky hub seal problem on same axl and hub.
    • #2 right side gets leaky every 6 months or so same hub.
    • What could it be ?
  3. Deere hunter
    2,171
    10,531
    Aug 5, 2017
    Shallowater Texas
    Did you change bearings and races also?
  4. Bernard D
    104
    27
    Jun 27, 2020
    • No sir ,but thanks for that because that just confirmed my thoughts and outers thanks.
    Deere hunter Thanks this.
  5. jamespmack
    How many miles on housings. My guess is the spindle is worn out, or ID of hub is worn out. Or possibly seal installed dirty or improper. Multiple possibilities.
    Hulld and Deere hunter Thank this.
  6. Deere hunter
    2,171
    10,531
    Aug 5, 2017
    Shallowater Texas
    Definitely a possibility, also check your breather tube to make sure your housing can breathe.
  7. jamespmack
    That will blow seals,but not normally the same one repeatedly. It will blow all of them, or oldest.
  8. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Also what kind of seal are you using? There is a difference.
    Deere hunter and jamespmack Thank this.
  9. jamespmack
    Thats the thing. Million different possibilities. Really need to teardown and have someone who knows whats going on look at it. Seen thousand of times people that don't know how or why to seal a stemco grit guard, then call them junk.
    Roger McG and Deere hunter Thank this.
  10. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Is it a Conmet type hub with the cone spacer between the bearings ? If so throw it out and set the bearing preload the conventional way. and us a stemco grit guard seal. we have had our best success this way.
  11. Bernard D
    104
    27
    Jun 27, 2020
    Thanks races, bearings,hub check out fine improper installs .
    jamespmack Thanks this.
