Hunts Point NYC Directions
Discussion in 'Experienced Truckers' Advice' started by DubbleDelta, Apr 11, 2024.
  1. DubbleDelta
    DubbleDelta Bobtail Member
    6
    17
    Apr 11, 2024
    I have a delivery to the meat side of hunts point. It looks like there is a route from I-95 to Sheridan Blvd, with an overpass that goes directly onto Edgewater Rd to Halleck Rd, and then straight into hunts point. (Picture Below) Does this route work with a standard 13’6” 53’ reefer? If not, what’s the safest way to get there?
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Yes….when you get to Hallack slight right….youll go along the produce mkt…thru next stop sign then left..,on what you’d think is wrong side of road
    Food Center is now one way..,keep the median to your right….go lil past 1/2 way around circle gate is on your left
    $30
    @DubbleDelta who are you delivering to?
    bzinger, DubbleDelta, Ruthless and 4 others Thank this.
  4. DubbleDelta
    6
    17
    Apr 11, 2024
    West Side Poultry. Im coming from Syracuse down 87 to 287 then back to 87. Did they just open that overpass recently?
  5. ‘Olhand
    6,750
    16,653
    Jan 18, 2011
    @DubbleDelta yes in the last year or so
    When you get off exit4 the Sheridan is no longer a highway…there’s traffic lites and crosswalks….instead of diving off 1st exit stay straight…the road splits…278riight….mkt overpass left
    NOW 278 is under construction….Do NOT follow detour signs at exit 4 You are good to go to mkt….but you’ll see the right split for the Bruckner Exp-I278 is barricaded
    bzinger, DubbleDelta, Ruthless and 3 others Thank this.
  6. DubbleDelta
    6
    17
    Apr 11, 2024
    10-4, I was scared to try that route if it wasn’t open yet. Looks like it makes life 10x easier getting into the market.
  7. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,559
    2,723
    Jan 7, 2023
    So they've re-constructed the area around Hunt's Point? Did they add a 'staging area' for the lot lizards, too?
    austinmike Thanks this.
  8. ‘Olhand
    6,750
    16,653
    Jan 18, 2011
    No they still hide behind the street lamps on Tiffany
  9. DubbleDelta
    6
    17
    Apr 11, 2024
    LMAO, I’ll let y'all know if I make it out.
  10. MACK E-6
    50,214
    240,288
    @Ruthless is probably our foremost expert on NYC.
  11. DubbleDelta
    6
    17
    Apr 11, 2024
    Thanks, hopefully @Ruthless can chime in as well. Much appreciate the help all!
