Hydraulic pistons not working right
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Jcurran90, Jan 11, 2017.
  1. Jcurran90
    Jcurran90 Light Load Member
    53
    8
    Apr 29, 2016
    I don't get it why do some of my hydraulic pistons move great up and down and slid great and some just go slow slow skow and sliding one of the deck is happening when a car is on it ... they look to be in good shape no leaks ... and what are you guys boosting you rpm up to when it's cold out ???
  3. SLANT6
    SLANT6 Road Train Member
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    When it is cold, you get what you get.
    When was the last time you lubed/slip plated your sliders?
    How about pump pressure? You did not say what kind of general shape your rig is in.
    brian991219 Thanks this.
  4. Jcurran90
    53
    8
    Apr 29, 2016
    Not sure what the pressure it that gauge isn't working the trailer is a 2011 cottrell high rail in very good shape angling to slip plate it tonight see if that helps but I really don't think that's going to have anything to do with how slow the decks are moving
  5. SLANT6
    1,094
    1,376
    Dec 3, 2012
    The Nut House
    A little slip lube in the right places makes a world of difference.
  6. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    Have you checked the hydraulic system, over time it can get contaminated and can get water then when it gets cold, it slows way down. Also how long since you changed the hydraulic filter?
  7. brian991219
    brian991219 Road Train Member
    3,000
    6,094
    Aug 10, 2013
    Lords Valley, PA
    It is not a good idea to bump up your RPM in the cold, run the pump at the RPM it is designed for. All increasing RPM does is put more volume and pressure into the system than it is designed for which will lead to early failure of many components. If it is only one or two functions that are acting funny you may have a valve that is stuck or has caught debris in the bottom of it. You may also have some dry spots that need slip plate as said above, or even a cylinder with debris or a bad packing.
    Are any of the slow moving functions showing any signs of leaking? How are the seals on the end of the pistons looking, especially the one that is sliding by itself with a car on it, sounds like either the valve body is sticking or the cylinder is leaking off.
    One more though on cold weather, if the functions you are having problems with in the cold also move slower than the other functions in the good weather it may just be the design of the truck and the cold weather is just amplifying the slow down.
    Ziggy319 Thanks this.
  8. AlexM
    AlexM Bobtail Member
    Did you figure out what was wrong? Having the same problem on a 2012 High rail
