I have a problem.
Discussion in 'CB Radio Forum' started by shannaparsons, Dec 21, 2016.
  1. shannaparsons
    shannaparsons Bobtail Member
    Dec 21, 2016
    My husband has installed a Cobra 29LX CB in his Jeep Wrangler. He had a 3' firestick mounted on the back tailgate, but it wasn't getting the best reception so he got a 5' firestick. He's getting less reception (by ear he's assuming when passing traffic) than he did with the shorter one. We've tried doing the SWR testing. Readings are as follows with BOTH antenna on :
    CH1: 2.3
    CH20: 2.3
    CH40: .3
    Why is it giving such a low signal on the 40 channel, I know it says that means more height, but he had thought he had better coverage with the 3ft. Could it be a bad ground?? Bad coax cable??? I've searched forums all night, trying to figure out why his "antenna warning" signal keeps going as well. I found that forum where it says to adjust the VR6 (so many digits I've had in my head, I think that's the right knob).. And I don't know who else to ask, before it gets smashed into a million pieces.
  3. MACK E-6
    50,061
    238,684
    Bad coax, perhaps?
    shannaparsons and bored silly Thank this.
  4. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    or a bad ground you have to experiment with the little things that might make a big difference... always look for the obvious that's wrong. usually when you figure it out its a aha moment and you think to yourself are you kidding me that's all that was wrong...
  5. Neverready
    Neverready Medium Load Member
    406
    330
    Jul 24, 2014
    Pocomoke City, Md.
    Leave the adjustments inside your radio alone. Antenna system is the issue. A friend had a wrangler to get rid of his antenna problems he had to do extensive bonding to eliminate swr and noise issues.
  6. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
  7. Ridgeline
    22,727
    123,503
    Start with this, just so you get accurate readings.
    Get an external SWR meter and a jumper and use that. Don't rely on the meter in the radio.
  8. shannaparsons
    Dec 21, 2016
    Thank you all. Antenna wasn't properly grounded. He actually found a CB shop, a gentleman ran testing with external SWR, got a little boosting and he's good to go. Thank you all for your replies, sorry for wasting your time.
    Big Don and rabbiporkchop Thank this.
  9. Ridgeline
    22,727
    123,503
    Not wasting our time, glad we could post something that may have helped.
  10. MACK E-6
    50,061
    238,684
    Nothing was wasted. This thread of yours could now help someone else who might have the same problem later.
    bored silly and Big Don Thank this.
  11. Big Don
    Big Don "Old Fart"
    17,996
    35,645
    Sep 8, 2007
    Utah's DIXIE!
    Absolutely! And Wranglers are notoriously hard to do a good, clean install in. Not the placement of the transceiver, but getting a good location for the antenna!
