I have some problems with my T680
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rick99, Jul 28, 2023.
  1. Rick99
    Rick99 Bobtail Member
    8
    Jan 1, 2016
    Hi, I have some problems with my 2017 T680 Paccar MX-13, Eaton Ultrashift Transmission. When I push the throttle all the way in, right after the gear is changing, sometimes the rpm drops while still on the throttle, then goes back to normal after. It sounds like air coming out when that happens. The other problem is when the jake brake is supposed to activate going downhill. After I do a down shift, instead of staying in gear and activate jake brake, it goes into neutral, the rpm drops, then goes back up, then down again. It does that a few times before the jake brake activates.
    Does anyone know what could this be?
    Streamable Video
    Streamable Video
  3. SharpShultz
    SharpShultz Bobtail Member
    8
    Jul 28, 2023
    I know the truck very well and the Cummings transmission is a step up for exactly what you're talking about. What you have IMO based on my
    history with this unit overall is an electrical/computer malfunction between the PACCAR Tmission and the brain aka software aka CPU.
    Here are some beginner things to check off... Power off the unit most units have the power off or kill switches down below by the seat belt near the base of the driver side door. Make sure your fuse box and fuses are normal. Check as best you can for any loose or faulty (female to male) wiring. If the kill switch doesn't fix or clear the error or issue you are having. There are some key/ignition turns or codes you may try for starters. Lastly, if you have a friend or you know how to plug into the truck with the proper KW software and a lap top do that. Some places charge out of the arse to do this alone and smile right in your face when you come to pick up the unit. Like they put in hours of work. I am just trying to help if some KW shop professional knows more than me you will be better off. I don't want to make your problem worse or be trolled because I am not spot on like a pro mechanic! I hope something helps or rings the bell so to speak LOL!! cheers Driver GL!!!
