i know nothing about trailer that makes things go brr
Discussion in 'Experienced Truckers' Advice' started by desertracer, Feb 26, 2021.
  1. desertracer
    desertracer Light Load Member
    66
    100
    Dec 31, 2018
    PULLED EVERY OTHER KIND OF TRAILER SO HERES MY QUESTION HOW FAR CAN YOU GO ON A TANK OF REFER FUEL GUESS IT WOULD BE UP TO HOW HARD THE REFER WAS WORKING THE LITTLE TANK SEEMS LIKE IT WOULD BE ALWAYS OUT OF FUEL THANKS
    austinmike and Lumper Humper Thank this.
  3. Six9GS
    Six9GS Road Train Member
    1,473
    3,697
    Dec 3, 2012
    Yuma, AZ
    I've been running reefer for almost a year and a half. I think the worst fuel consumption I've experienced would get between 3 and 4 days on a 50 gallon tank. Best usage would probably last close to 2 weeks. Many factors involved in how much fuel gets consumed.
    Just be aware, once the reefer gets down to 1/4 tank, you need to get fuel really soon. That last quarter of a tank goes really quick!
  4. 88 Alpha
    88 Alpha Trucker Forum STAFF Staff Member
    5,595
    18,184
    May 12, 2012
    SouthEast Alabama
    We are dedicated to a chicken plant and our trailers are rarely set to anything other than -10* and not turned off very often. We have 50 gallon fuel tanks and they burn 25 gallons/day during the summer. We can go a little longer during the winter.
    The customer rented some former Prime trailers with the 30 gallon tanks last summer. They would run out before 24 hours was up. Needless to say, when the contract was up, the customer got trailers with 50 gallon tanks.
    tscottme, D.Tibbitt and magoo68 Thank this.
  5. JerzyG
    JerzyG Light Load Member
    93
    265
    May 23, 2020
    Personally, I go by the rule of 1 gallon per hour if running continuous.
    mitrucker, tscottme and D.Tibbitt Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,378
    6,253
    Nov 16, 2013
    Baltimore, Maryland
    It depends on the temperature outside, the temperature you have the reefer set to, and if you are running the reefer on start and stop or continuous. Also the age of the trailer plays a part as well.. For example, if you have a frozen load set at -10 and its 98 degrees out, the reefer will be hammering and sucking fuel.
    tscottme and nredfor88 Thank this.
  7. WesternPlains
    6,353
    56,636
    Sep 1, 2017
    Rapid City, SD
    Perhaps you don’t know yet.
    That trailer can and is used to keep things warm. Example... temp set 50 f. Outside temperatures below zero.
    tscottme Thanks this.
  8. snowwy
    snowwy Road Train Member
    20,591
    13,311
    Jul 6, 2009
    Winter will last longer then summer. And will probably last longer as a heater vs. Freezer. Not using the ac compressor.
  9. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,861
    Apr 29, 2020
    I do not believe that is a correct statement. My assumption is that the reefer unit is a heat pump, similar to the ones used in residential homes. The compressor is used to both heat and cool. Somebody correct me if I am wrong. I doubt that there is a heating element in those trailers?
    nredfor88 and Cowboyrich Thank this.
  10. snowwy
    20,591
    13,311
    Jul 6, 2009
    radiator? Or heater core?
    Ac compressor uses more fuel.
    I believe it's a correct statement.
  11. Dockbumper
    3,778
    9,861
    Apr 29, 2020
    Thanks, I also have no clue how those units operate. I never thought about the cooling system radiator/heater core angle. That is why I like these forums. I'm getting older than dirt but still willing and able to learn:D
    rolls canardly and gentleroger Thank this.
