I need a nox sensor
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jdb1997, Jul 19, 2021.
  1. jdb1997
    jdb1997 Bobtail Member
    6
    Dec 18, 2020
    I have a 2015 Peterbilt with a mx-13 engine. I need an intake nox sensor and my local dealer says it will be 4-6 weeks and that is just an estimate. Anybody have any idea of what else I can do other than wait?
  3. Arctic_fox
    4,519
    25,569
    Sep 16, 2016
    Get the part number and start calling kennys and peterbilts in an ever widening circle around you. If you find one buy it and have it overnighted to the dealer your at. You can also look for used ones or aftermarket to limp with till you find a new one.
    Also if a nox sensor failed id have your EGR checked. It can be a symptom of a clogged system and your EGR may need a clean.
    Wespipes Thanks this.
  4. AModelCat
    164,842
    Yep. Start calling. Whole supply chain is buggered.
  5. Ridgeline
    22,730
    123,528
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Goodysnap, Oxbow and baha Thank this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,773
    9,199
    Jul 12, 2017
    Nox sensors, DPF pressure sensors, DEF quality sensors, exhaust flex pipes, DPFs, clutch ECAs are all coming up frequently on B/O. Paccar is all but done giving ETAs on parts due to unreliability. Naturally the top fleets purchasing trucks are gonna get first pick, which is too bad. Leaves the little guys struggling.
    spsauerland and QUALITYTRUCK Thank this.
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    go to a salvage yard get a used one
  9. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    try calling overseas, believe those engines are also used in Europe. as well as dealers and parts houses in US
  10. jason6541
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Didn’t Paccar buy DAF in Europe and MX13 engine is a variant of the European model
  11. Goodysnap
    3,773
    9,199
    Jul 12, 2017
    The core engine itself was imported from DAF Europe. The components attached to it and the engine was adapted and modified to meet North america EPA standards. All of the aftertreatment components are actually provided by Cummins for all of the MX engines since production began in 2009.
