I need advice about removing my automatic restriction
Discussion in 'Experienced Truckers' Advice' started by BillyBobFrank, Jul 29, 2024.
  1. BillyBobFrank
    BillyBobFrank Light Load Member
    208
    388
    Nov 7, 2022
    I've been driving for 2.5 years and I'd like to broaden my options by eliminating my auto restriction, but I have a couple questions.
    1) When doing the driving test at the DMV, do they provide the truck you'll be driving?
    2) I know how to drive a manual in a 4 wheeler, but I've never driven a manual in a truck. From what I've seen in YouTube videos, it seems very similar, just switching from low to high. Do you think I'll need to find a school to practice before testing? This brings me to my last question...
    3) Are there places that'll let you train for an hour or two for a reasonable cost?
  3. Ridgeline
    22,750
    123,993
    No, you provide the truck, and don't drive it there.
    Yes it is very similar, more gears and more shifting but overall it is the same.
    Yes you have to look for them and call around. Some places will even provide the testing or arrange for it.
  4. Accidental Trucker
    Accidental Trucker Road Train Member
    3,442
    7,844
    Jun 4, 2015
    While the concept is the same, shifting an unsynchronized transmission like a semi truck takes a LOT more time to master than shifting a six speed in your car.
    A couple of hours is not enough to be proficient enough to go take the test for most people. Not sure how easy it is to find someone to volunteer their truck for you to grind your way to proficiency, either.
    Makoman, W923, mitmaks and 4 others Thank this.
  5. Concorde
    Concorde Road Train Member
    5,506
    19,594
    Jun 29, 2016
    West Melbourne Florida
    Yah, you’re going to need a school for training..an hour or two isn’t going to cut it.
    About the only thing similar between a manual truck and a 4wheeler is a stick and a clutch. You’ll be needing to learn to double clutch and having the engine rpm’s just right. Miss a shift causing you to stop and try again during a test you’ll be failed.
  6. tscottme
    tscottme Road Train Member
    Experience shifting gears in a 4-wheeler WILL MAKE IT MORE DIFFICULT to shift in a truck. The clutch is used completely different, but you will keep using the clutch in the truck like in a Honda Civic. You will need to unlearn the 4-wheeler shifting technique and then learn the 18-wheeler shifting technique. For example, 4-wheeler shifter ALWAYS ALWAYS ALWAYS press the truck clutch too deep. This makes it almost impossible to get the truck into gear. In the truck you ONLY USE JUST ENOUGH clutch, maybe pressing it 1/4 or 1/3 of the distance toward the floor. In the 4-wheeler the one universal truth is the clutch is pressed fully to the floor or it is fully away from the floor.
    Once you learn how to upshift (like when you are accelerating) you will quickly get to a point and think you are almost ready to go solo and then you will have to downshift (like when slowing) and NOTHING is working like it was before. It's like almost everything you learned to upshift no longer works. This is because you are pressing the clutch too deep.
    It takes CDL school about a week to teach newbies to shift. It's not nearly as hard as most people think, but it not's like what you think it should be, so it feels hard at first. You will likely need to find a school. On test day, the school instructor or a CDL driver without a Auto restriction needs to drive the truck and you to the test site. It is illegal for the student (you) to drive the manual truck to the test site on public roads unless you have a manual-legal CDL driver in the truck.
    brian991219 Thanks this.
  7. Diesel Dave
    9,729
    33,319
    Jan 20, 2010
    Hesperia, Ca.
    Keep us informed on how you took care of this. Question, why didn’t you go for the non restriction in the first place ?
    tscottme Thanks this.
  8. staceydude
    staceydude Road Train Member
    1,151
    5,041
    Apr 3, 2020
    You can get your auto restriction lifted by renting a truck that is just large enough to pull a 28’ trailer and they shift like a regular ol pickup truck (at least in Texas you could)…
    However you will see there is a world of difference between shifting that and a real 10/13/18 speed. They don’t shift the same as has been noted by a few. You need to be at the right rpm that matches the gear you are in and downshifting is a whole new ball of wax, so before you jump in a truck for a road test with a company that owns manuals you wants some time in a “real” truck or you will look like a complete fool.
    So best bet is to seek out a place to take some lessons from and get some practice time so you have some hands on knowledge and skill.
  9. Blagoje
    Blagoje Medium Load Member
    441
    961
    Jul 14, 2022
    Paris, Illinois
    I say don't even bother with manual transmissions as the entire industry is shifting towards automatics (no pun intended).
    ncmickey, ibcalm19 and Diesel Dave Thank this.
  10. Diesel Dave
    9,729
    33,319
    Jan 20, 2010
    Hesperia, Ca.
    My thinking exactly.
    ncmickey, ibcalm19 and Blagoje Thank this.
  11. Dennixx
    Dennixx Road Train Member
    4,549
    14,646
    Feb 13, 2010
    twin cities
    There will ALWAYS be a place for those that can operate old iron and specialized equipment.
    Just not as easy today to get the experience on someone else's equipment.
    W923 and Numb Thank this.
