I never had a brake chamber explode like this before
Discussion in 'Experienced Truckers' Advice' started by mp8327, Feb 4, 2025.
  1. mp8327
    mp8327 Light Load Member
    99
    93
    Jan 17, 2014
    I have had them fail before but not explode like this, good it was just a storage trailer I had to move from the yard to a dock. Happened about halfway in the dock ,I managed to push it in there
  3. bad-luck
    bad-luck Road Train Member
    3,450
    6,366
    Nov 16, 2013
    Baltimore, Maryland
    I have never seen that before
    Bean Jr. and tscottme Thank this.
  4. AModelCat
    165,158
    Corroded to ####. I bet the rest aren't much better.
    MACK E-6, 86scotty, mtoo and 4 others Thank this.
  5. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    The other three are ticking time bombs. I'd be extremely cautious around them or just avoid all together.
  6. Arctic_fox
    4,556
    25,919
    Sep 16, 2016
    Ive had a couple do that. Usually its heavy corrosion or a failed weld. Saw it occasionally out in the oilfields when the cans were constantly covered in chemicals salt and worse that ate into them over time.
  7. 201
    201 Road Train Member
    12,834
    26,422
    Apr 16, 2014
    high plains colorado
    Like the broken steer axle spring, cheap Asian junk metal.
  8. Hammer166
    7,614
    27,839
    Aug 18, 2007
    ~8600+' and loving it!
    Rapid unscheduled disassembly, that is!
    broke down plumber and D.Tibbitt Thank this.
  9. MACK E-6
    50,173
    239,826
    That could’ve ended badly if somebody’s face were near it at the time. :eek:
