I read several post about coolant issues. please help.
Discussion in 'Ask An Owner Operator' started by selftaughttrucker, Oct 23, 2018.
  1. selftaughttrucker
    selftaughttrucker Bobtail Member
    35
    29
    May 21, 2015
    Baltimore, md
    I use gloves and I do turn it very slowly because I knew it may have had pressure build up. The trucking Gods was looking over me that day.
  3. selftaughttrucker
    35
    29
    May 21, 2015
    Baltimore, md
    The picture is the top part that feeds into the air compressor and it is held on the motor by a bracket. I tried looki it up anybody know what it is?
  4. mastllc
    mastllc Medium Load Member
    379
    150
    Aug 28, 2008
    somewhere in ga
    Looks like it's on a 14l 60 series Detroit, I'm not sure what's it's called, but on those engines when the put pressure into the surge tank it's usually the head gasket. You can take a water bottle with some water in it and stick thebover flow tude in it and if it make bubbles with the truck running there's a problem. Or take an empty one a zip tie it to something and stick the overflow tube in it while you drive and if there is coolant in it after a drive( if the tube doesn't blow out) that usually means there pressure in the system and usually that's from the hea gasket.
    Rideandrepair Thanks this.
  5. Rideandrepair
    17,540
    56,830
    Aug 8, 2015
    Compressor head gaskets can also fail and put air into coolant
  6. JAD1024
    JAD1024 Light Load Member
    57
    21
    Apr 9, 2018
    What did your problem end up being ??
  7. Evil_E
    Evil_E Heavy Load Member
    790
    537
    Nov 25, 2011
    Dexter,MI
    Could also be air compressor if it's water cooled. Can't bad injector cups cause aeration in the coolant as well?
    JAD1024 Thanks this.
  8. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Injector cups will usually put fuel in the coolant.
    danny23tx, Evil_E and Muddydog79 Thank this.
  9. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    yup had a old Box truck that had sat for most of the year and the cups went bad .
