I Shift issue
Discussion in 'Volvo Forum' started by AlexD13, Jan 8, 2020.
  1. AlexD13
    AlexD13 Light Load Member
    138
    26
    Jun 13, 2016
    I am experiencing issues while taking off , turning and on reverse. It feels like something is holding it back from Getting into gear. I have no Check Transmission lights . Anyone have that issue? 870k Miles Volvo I shift Trans.
  2. Truth Lover
    Truth Lover Bobtail Member
    7
    Sorry to tell you but no one even in Volvo's dealerships can fix anything with automatic transmission. I personally spent months and more then $40000 to fix my automatic transmission issues and after all my problems wasn't resolved correctly. So I sold my Volvo and bought old designed Freightliner columbia with manual transmission. I learned on internet videos how to use manual transmission and since 2015 had no problems with my transmission. And if I had I know that any shop can install new manual transmission for $3500-$4000 . Do not waist your time and money to fix automatic transmission. That is all I want to tell you.
  3. AlexD13
    138
    26
    Jun 13, 2016
    I have had 1 past issue before but it was just a harness. It is not easy to swap out for this for a automatic
  4. sirjeff
    sirjeff Medium Load Member
    332
    905
    Dec 1, 2013
    Kelowna, BC
    I had a problem with the clutch control valve which exhibited similar symptoms
    If it were my truck, I would pop into a dealer and have them run diagnostics/calibration on the CCV. it should only take 20 or 30 mins in tech tool.
    I was convinced my tranny had to come out to have the ribbon harness replaced - turned out the valve was bad. 700$ or so and an hour labor including diag and all was good again
    Doealex, Bakerman and AlexD13 Thank this.
  5. AlexD13
    138
    26
    Jun 13, 2016
    Thanks brother, i replaced that less than 2 years ago, maybe that is bad. I also got an ABS light that turned on.
    sirjeff Thanks this.
  6. sirjeff
    332
    905
    Dec 1, 2013
    Kelowna, BC
    No prob,
    My original one lasted 5 years before it packed it in, if yours is only 2 years old then hmmmm
    I would look into the abs fault. A good volvo guy that used to work on my truck (before he went from being a volvo/mack shop to western star/freightliner shop) explained to me that the tranny uses abs input from (if I remember correctly) the front left wheel speed sensor. In my case, the abs faults weren't the problem, but they CAN throw your tranny out of whack. It's a long shot, but way cheaper than pulling your tranny out to look for things.
    Also, I shifts can be rebuilt now. No more 25k I shift re/re jobs!
  7. AlexD13
    138
    26
    Jun 13, 2016
    I just checked in into the Dealer. They will look into this matter. As I was driving it to the dealer the ABS light turned on. I changed the Brake switch on the firewall yesterday when it came on. This all happend after changing the brakes.
  8. AlexD13
    138
    26
    Jun 13, 2016
    Would you put on a new ishift or just sell in my shoes? I got 850k and just put new EGR
  9. nasriza
    nasriza Road Train Member
    1,954
    1,528
    Feb 1, 2013
    Chicago, IL
    you can get them remaned from volvo it has never been 25K maybe thats what it turns out to be at the dealer but you can get one in for less than 10K usually.
    Doealex Thanks this.
  10. AlexD13
    138
    26
    Jun 13, 2016
    Where? What brand
  • Draft saved Draft deleted
