I shift issue
Discussion in 'Volvo Forum' started by 05vnl670, Oct 1, 2022.
  1. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    Hello
    I have a 2014 d13 with I shift and 560k on it.
    When driving in traffic seems like the clutch is not disengaging and I have to put it in neutral.
    I have PTT and there are no faults in the engine or transmission and i performed test clutch leak test and clutch performance and both passed. Any ideas?
  3. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    You will not have any active faults unless problem is happening constantly give me a list of the inactive faults you have chances are clutch actuator is not disengaging. Either clutch solenoid valve is not working or actuator is acting up either or.
    MartinFromBC Thanks this.
  4. 05vnl670
    165
    60
    Feb 17, 2013
    There is no any faults. Active or inactive. I have PTT. Another symptom I have now is that I have no response to gas pedal, I have to come to full stop shift into neutral and then D.
  5. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Something is going on from trans there is no way it will not have any faults any time it cuts out gas pedal is the trans protecting itself from more damage from driver.
  6. 05vnl670
    165
    60
    Feb 17, 2013
    Do you know how to adjust micro switch without the special tools?
    I want to make sure that is good.
