i-shift problem ,help please
Discussion in 'Volvo Forum' started by charlie747, May 24, 2015.
  1. Adil84
    Adil84 Bobtail Member
    49
    5
    Dec 4, 2013
    Hi man
    I have the same problem i attached some pic onf the code i got . Can you please help fond the problem with my ishift .
  3. DaroAZ
    DaroAZ Bobtail Member
    4
  4. DaroAZ
    4
    Is nothing electrical, not selenoid, is mecanical issue inside , probably drum in the back part of transmission or bearings wear out. Nothing you can do by your self,need special volvo puller to remove gears inside. Limited parts availability at volvo dealers also. There is aftermarket parts suplier selling parts in US but you need someone who know how to work on this
  5. DaroAZ
    4
  6. DaroAZ
    4
    Idk how this side work ,i am new here but my opinion is that transmission have mecanical issue. Also relay for the transmission in fuse box ,under dash can do it ,but most time it is mecanical issue. Idk how you can contact me str8 and if i will see any responses here, but just in case my phone number is 6027945063 or email djk301@gmail.com
  7. Adil84
    49
    5
    Dec 4, 2013
    Hi Alex
    Can you please help im having same problem with my ishift throwing code mid 130 pid 161 fmi 1 . Did you fix yours ?
  8. Dacha09
    Dacha09 Bobtail Member
    Any news? Did you fix yours?
  9. uzb-trucker
    uzb-trucker Bobtail Member
    10
    Hi there, I have 13 Volvo vnl730 D13 engine I-shift transmission.acting same as yours, after driving around 50 miles check transmission message pops up and losing power, gas pedal become so soft no rpm at all after I pump the gas pedal it's slowly building and truck keeps moving , no fault codes or check engine light, sometimes when driving up hills or at the traffic light truck just loses power and gas pedal does not respond at all. Please help what could be the issue? Thanks ahead.
  10. Arielcuba
    Arielcuba Bobtail Member
    Hi. Thank you very much for the information. This year 2019 I had the same problem in a truck that presented the same symptoms. Thanks to you I could solve the problem, but I still have a doubt, the relay that energizes the control unit of the I-shift works very hot from my point of view. Anyway, the truck has already worked 3 weeks without problems, like new.
    thanks again
  11. AlexD13
    AlexD13 Light Load Member
    298
    86
    Jun 13, 2016
    Hey how is your tranny doing?
