If you have the D13 there should be 7 years or 750,000 mile warranty on that transmission. The dealer will be able to pull codes and contact volvo e service
i-shift problem ,help please
Discussion in 'Volvo Forum' started by charlie747, May 24, 2015.
Page 2 of 13
I have 610,000 do now if the warranty if up to 750,000 or 500,000?
I will do that
7 years or 750,000 miles, which ever comes first
charlie747 Thanks this. -
The thing is that Is not showing any faults codes i take to the dealer and they say not codes no found any problems, but again after i drive 65 mile was doing the same, you say in amarillo don't change the Top , they change the bottom (transmission)? How long that take?
Maybe no active codes, when the problem happens, does your truck say check transmission? If it does it stores codes. Volvo then sends off the codes to E service then they tell them what to do. My case took 2 weeks to get me out the door due to shipping issues because they didn't have one in stock.
Yes when the problem happen it saying "check the transmission at the next stop"
I going to take the truck to the dealer in FL, and let see if I have lucky there, definitely not back to the dealer in houston they #### my hole engine too. -
Sweeten truck center in houston is one of the worst dealers in america. I find most of the dealers in the states try to screw you over warranty. Amarillo was pretty good. Same with the one in st. George utah. I use red deer,ab and Calgary most.
Yes is what they try to do saying that the transmission don't have no more warranty after they do the update, hard to believe how those guys keep running a dealer!
Thank you again and I fallow your advice -
Hey, what ended up happening to your ISHIFT.? What did they change on it?
Page 2 of 13
