i-shift problem ,help please
Discussion in 'Volvo Forum' started by charlie747, May 24, 2015.
  1. Goffery1
    Goffery1 Bobtail Member
    4
    Ben can you call me I have a question about the I shift transmission: 678-343-0965
  3. AlexD13
    AlexD13 Light Load Member
    298
    86
    Jun 13, 2016
    Hey what ended up happening?
  4. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    I need more information about the fault code list and their Counts,
    If you have high inactive count of code Mid 130 PSID 25 FMI 7 , did your HI-Range - Low Range 6 th and 7 th work fine up and down(no grinding) ? If so, you have probably a ribbon tape problem (inside the transmission) for the Warranty coverage question, need to be check with your Truck serial number on the Volvo system.
    Hope this can help.
    Ben
    zeeshanaslam Thanks this.
  5. AlexD13
    298
    86
    Jun 13, 2016
    Mechanic said Pid161 fmi 1.. the truck runs fine then loses power and says check transmission at next stop
  6. AlexD13
    298
    86
    Jun 13, 2016
  7. Ulav74
    Ulav74 Bobtail Member
    7
    Jun 8, 2013
    Im having problem whit i shift .Hi gear and low gear 6 to 7 gear making noise when shifting. What does that mean?
  8. AlexD13
    298
    86
    Jun 13, 2016
    Did you look into this?
  9. Ulav74
    7
    Jun 8, 2013
    Got it to volvo . Gound inactive code for Range selector . Volvo says replace whole transmission. Truck runs only making sound from 6 to 7 i shift
  10. Ulav74
    7
    Jun 8, 2013
    Transmission ECU code P107292 Range Engagement System unoperational or incorrect it is incorect
  11. AlexD13
    298
    86
    Jun 13, 2016
    What year? Miles?
