I think I'm over weight
Discussion in 'Questions From New Drivers' started by gentleroger, Oct 14, 2019.
  1. gentleroger
    gentleroger Road Train Member
    7,895
    21,600
    Jun 1, 2010
    The shipper is closed and my driver manager Vlad says I'm under 80,000 so its good to go, but I'm a little nervous.
    What should I do?
    JC1971, 91B20H8 and tinytim Thank this.
  3. skytrash
    skytrash Light Load Member
    211
    368
    Apr 6, 2017
    denton , tx
    run with it, and when you get pulled around back at the scale house just give them Vlad's number and tell them he said it was ok
    Woodys, JC1971, LoneRanger and 13 others Thank this.
  4. tarmadilo
    tarmadilo Road Train Member
    1,731
    4,771
    Dec 12, 2018
    Are your tandems all the way back? Move them up all the way forward and see what you get!
  5. Opus
    132,318
    Looks like you're good on your steers and trailer. I'd say run it. I mean, 2 out of 3 ain't bad....cue Meatloaf
  6. stwik
    168,151
    You left #### near 2500lbs on the table! What is you doing!
  7. gentleroger
    7,895
    21,600
    Jun 1, 2010
    That is after moving them all the way up.
    Even if they were all the way back, 20 holes x 300 lbs =6,000 lbs. I would still be a tad over. I would get under the axle rating though.
    FlaSwampRat Thanks this.
  8. Long FLD
    Long FLD Road Train Member
    12,881
    53,929
    Mar 4, 2015
    Run it. If you get called into a scale just tell them you’re on your way to get another axle installed.
  9. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,118
    2,079
    Oct 23, 2018
  10. Dennixx
    Dennixx Road Train Member
    4,542
    14,605
    Feb 13, 2010
    twin cities
    Sounds like a crash course in the fine art of scale dodging
  11. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    I could also lose 20lbs.
  12. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Personally I'm about a fluffy 300 lbs.
    Vlad the implaler don't know Jack! And he can pay the near $1 per pound over axle weight. Or pay you to dodge scales like the Snowman!
