I50
Discussion in 'Experienced Truckers' Advice' started by I50, Mar 19, 2013.
  1. I50
    I50 Light Load Member
    110
    38
    Mar 19, 2013
    I am retired after 6 years because I could no longer fake the physicals. You know, not eat and drink lots of water for 3 days so my blood pressure and blood sugar are low enough to pass. I drove for Dick Simon until his sons drove his business into the ground. Then I drove for Werner. There are no "good" trucking companies and the ones I drove for I considered better than average for different reasons. And while most truck drivers are better than your average driver I have seen too many that should not be behind any wheel. One of the first things I noticed while driving for Werner is that almost all their trailers had cupped tires and that most of their trailers desperately needed a brake adjustment. Since I figured that they must be leaking air I filled all the tires to their maximum limits with dry air from the trailer brakes so they rode on the uncupped portions of the tread. Then I would find a place to back up the trailer and separately apply the trailer brakes to adjust the trailer brakes. It wasted 30 to 45 minutes of my time to do this but I took safety seriously. Then I picked up a brand new trailer and found out they come from the factory that way with underinflated tires and unadjusted brakes. That was trailer 40000. Occasionally I would pick up a trailer that seemed to be OK but when I checked my paperwork I discovered that I hauled that trailer before. Every winter when heavy snows were coming down there was always one truck driver passing me quickly to be the first one at the scene of the accident that would have me and all the other drivers waiting for hours. On I-80 westbound in Montana I saw many truckers pass me in a strong headwind and get blown off the road in front of me. On I-80 eastbound I saw antelope crossing the highway so I blinked my lights to let oncoming traffic know there was a problem up ahead and an owner operator plowed through and killed 5 antelope. I remember one antelope with all his legs broken completely off still upright and looking around dazed. Owner operators are usually more professional because they must be responsible for their own rigs. But some owner operators are that way because no decent trucking company would ever hire them. You can usually tell who they are because they don't maintain their rig. Cupped tires on a tractor are a dead giveaway. There are still way too many truckers impatiently tailgating cars in front of them. That is why I believe that trucks should be compelled by law to go 3 mph slower than the speed limit for all other vehicles on the road. No slower because differences in speed increase the likelihood of accidents. No faster because it would increase the likelihood of tailgating with not enough reaction time to respond to unexpected trouble where the innocent are most likely to die. And you will see unexpected coincidences.
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    the reason the brakes are out of adjustment is becuase the automatics aren't working. it's a very common problem. which means backing up and slamming is just a waste of time. it's also a common problem that drivers just don't care about there brakes. and bother with adjusting them.
    all these accidents you see. and hear the driver say the brakes quit working. well, there's your answer.
    tell dot you had no brakes and the first thing they look at is adjustment. and thickness
    it takes 1 minute to adjust the brakes by hand. and you KNOW where your brake adjustment is at. and you can drive down the road KNOWING your brakes are adjusted. then you can get the trailer to a shop to have the adjusters replaced.
    80 goes through wyoming. 90 goes through montana. :biggrin_25525:
    mavljc and Logan76 Thank this.
  4. Numb
    Numb Crusty Curmudgeon
    4,333
    10,298
    Jan 30, 2012
    Charlotte, N.Carolina
    don't let the DOT catch you adjusting brakes, unless you are a certified mechanic.
    once u touch them YOU are liable in the event of an accident.
    been told that by the DOT in the US and Canada. u ain't certified, don't touch 'em.
    sound s like your 6 yrs made you a bitter x-trucker.
    Lonesome and Tonythetruckerdude Thank this.
  5. Real Deal
    Real Deal Medium Load Member
    468
    230
    May 29, 2012
    Saint George UT
    Putting bad information on here is not good.
  6. jbourque
    jbourque Heavy Load Member
    924
    553
    Oct 25, 2012
    south english iowa
    if i had that much trouble in six years would have quit too
  7. Real Deal
    468
    230
    May 29, 2012
    Saint George UT
    If you had high blood pressure and high blood sugar you didnt have any business on the road at all.
    j3411, hhmag70 and Tonythetruckerdude Thank this.
  8. Numb
    4,333
    10,298
    Jan 30, 2012
    bad info??
    it's the freakin' truth. stop in a scale house and ask them.
    Ontario told me if I touched them they would shut me down. QEW north of US border.
    Missouri told me the same thing. I-35 north of KC,northbound side.
    companies like to tell you to do it, even give you a 5 minute course.
    does not make you certified. they just want to save money. and shift responsibility back on driver.
    believe what you want.
    Tonythetruckerdude Thanks this.
  9. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    links ?...........
  10. 123456
    10,555
    5,748
    Oct 22, 2010
    32179
    Whats retirement pay after 6 years ?
    couldn't be very much.
    Tonythetruckerdude and Lonesome Thank this.
  11. Numb
    4,333
    10,298
    Jan 30, 2012
    links??
    I didn't film it for you tube.
    I also didn't ask them to show me where it was written.
    just said,"yes,sir" and did as requested.
    forgot to add NY DOT on I-88 rest area check. was told the same thing.
    brakes were good,but I asked about it.
    maybe they were all b/sing me or it's a scam for their cousin who owns the local truck repair shop.
    no matter. I didn't need to be ticketed.
