Ice
Discussion in 'Questions From New Drivers' started by Coffey, Jan 20, 2020.
More info I'm on a gravel driveway with a area of about 1-2 inches of broken ice around my tire and I'm just spinning away and can't get traction
How long have you been there? Just pull up? Parked overnight? Truck and trailer?
Coffey Thanks this. -
Got here about 10 mins ago with truck and trailer
People should be getting here in about half an hour that should help but I would like to get out before then
If you can get some loose gravel to put in front of your tires that might help. I would wait for 10-15 minutes before trying again. Sometimes when you tires cool a little your traction will improve. At any rate you are probably not the first truck to get stuck there so the people there may be able to help.
Thank the farmers had got here there getting a tractor to pull me out and the guy who was supposed to load infornt of me made it around
Flat Earth Trucker Thanks this. -
If you have a manual transmission and are light, try starting out in 4th or 5th gear. But engage the clutch very slowly.
You want the tires to spin slowly.Coffey Thanks this. -
I unfortunately got an automatic but I try to make it do something like that when I get stuck again.
it's kind of ironic the only place with ice is where I get stuck guess I need more experience in snow/ice -
that's where I got stuck told I hit it going to slow and I probably did
Flat Earth Trucker and mhyn Thank this.
