Ideas that help drivers out new and old.
Discussion in 'Experienced Truckers' Advice' started by notarps4me, Jan 4, 2010.
  1. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    You ever find yourself with a problem and found out a way to correct it? How about posting them here so others can benefit.
    Problem.
    One problem I have had in the past with freightshakers was the driver side windshield ice balling up on the wiper arm and the windshield not giving me a clear field of vision. The aggravating part is the passenger side is always crystal clear. Pulling over every few minutes is out of the question. I even tried rolling down the window and grabbing the wiper blade and pulling it out and letting it snap back to the glass to knock the build up on it when it goes to the up position. Even with the heat on the floor and not the windshield (defrost) this always seems to happen.
    Solution.
    What I did find that helped is putting a wiper huggie (sold in stores) on the driverside wiper arm. This put more tension on the blade and did help some on the problem.
  3. uhoh
    uhoh Bobtail Member
    22
    8
    Nov 3, 2007
    Waco, Tx
    Never try to thaw a frozen turkey in the clothes dryer.
  4. tinytim
    tinytim Road Train Member
    5,145
    19,239
    Oct 29, 2007
    Northern Ontario
    Thanks, I'll try that.
    Now, any suggestions on how to stop the problem of more washer fluid ending up on my mirror than on the windshield?
    pinballwizard and JustSonny Thank this.
  5. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    I had that problem with one truck. (columbia) I would slide that liitle black piece that clips on the wiper blade around until I got it where it did not do it as bad... then it would do it again. I had another columbia that I never had that problem with it. Good luck on figuring that one out.
  6. DannyB
    DannyB Medium Load Member
    353
    670
    Apr 13, 2008
    Jackson Mi
    I bent the hose on the passenger side until it was almost pinched shut and hold it in place with a large paperclip. Then I reamed the hole on the end of the spray nozzle on the drivers side, making it about half again as big as the others.
    Doesn't keep the fluid from getting on the mirror, but it does get more of it on the window where the wiper can get more use out of it. ;)
  7. Jack Smithton
    Jack Smithton Light Load Member
    256
    167
    Jan 1, 2009
    so cal
    This could be a good thread - I thought I was the only one to reach out of the window to snap the wiper blade! . . .
  8. Gearjammin' Penguin
    2,735
    8,518
    Feb 18, 2007
    Central AZ
    Preheat the windshield.
    At the first sign of snow/sleet/etc, max out the heat and turn on full defrost. If you're roasting, crack your window. It might not stop your wipers icing up in an all-day blizzard, but it dramatically improves things for quite a while.
    JustSonny and pinballwizard Thank this.
  9. Yatista
    Yatista Medium Load Member
    479
    207
    Jan 25, 2009
    Upstate New York
    If the outside temp is not too low the defrosters will help. If the window and wiper continue to ice up it's time to switch gears. Put on your coat, turn off the defroster, just a little heat on your feet. After cleaning the windshield and wiper of ice you will not get any more. If nothing melts (it's too cold) it will just blow away. Requires cold temps, not 29 and sleet, to work
  10. Truck Driver
    Truck Driver Medium Load Member
    330
    136
    Dec 5, 2007
    Sacramento, CA
    Your mirrors may be to far forward. The Columbia I was in for a little while had that problem and the old Century I'm in now never had it. The mirrors on the Columbia were set farther forward than the ones on the Century. I could have moved them back but I never bothered to.
  11. notarps4me
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Read up on my post on that.
    JustSonny Thanks this.
