idle down to cool turbo
Discussion in 'Trucks [ Eighteen Wheelers ]' started by earthmover, Nov 18, 2011.
  1. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    do you guys let your trucks idle for a few mins after you have stopped to let the turbo cool/oil drain back down or is that a old wise tell????
  3. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    This is true fact and when you practice this you will extend the useable life of your turbo.
  4. rollin coal
    rollin coal Road Train Member
    13,634
    28,027
    Mar 29, 2008
    TN
    Yeah at least 5 minutes maybe longer, especially if a hard pull, heavy on a hot day. When the outside ambient temps are cooler, winter time, just easing around from the top of the get off ramp to the fuel island is usually sufficient because my oil temp usually runs about 25* cooler in the winter. I base it on what my oil temps normally run and what my gut tells me to do. If you don't allow the turbo to cool down you are letting the oil inside the bearing get extremely hot, hot enough to cook itself. Exhaust flows through the turbo at almost a 1000* or more. My oil temp normally stays about 175* or sometimes might get to almost 200* on a hot day. 150*-160* in cold winter temps. It shouldn't go higher than that (200*) imo. You risk shorter bearing life in the turbo by not cooling it down. Definitely not old trucker's tale, just plain old common sense...
    Diesel Dave and TachItUp Thank this.
  5. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    Even the cummins manual states you should allow some time to cool down. It all depends per what rollin coal stated above.
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    It was necessary when the coking point of the oil was low, If you pull hard to the top of a hill let it cool down, 99% of the time you gear down, and slow down and coast, the engine will have cooled and by the time you do your log or get your stuff ready to leave the truck, do a walk around, you can shut it off maximum 3 minutes.
    As a mechanic, I got to see a lot of failures of turbo's, pre filling oil filters, starting the truck without touching the throttle. That saves turbo's.
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    ROFLMAO!!!!!
    The failings of the public education system.
    Dude you need to start reading books. You can't learn the language just from what you hear and try to spell out how words sound. Start reading now! There's plenty of four year olds that have a nice head start on you already!
    And why do people use phrases that they have no idea of the meaning? If you knew what it meant you'd surely know the correct words of the phrase and not just the approximate sound.
    I'll help you out earthmover. It's "old wives' tale" http://en.wikipedia.org/wiki/Old_wives%27_tale
    LOL I probably just made another enemy but I just couldn't pass on an "old wise tell".
  8. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    That's why even the DPRK gives you at least 5 minutes to idle.
  9. Semi Crazy
    3,033
    2,047
    May 13, 2011
    Middle Tennessee
    It's not the oil temperature it's the temp of the turbo that matters. If you don't have a pyrometer you'll never know when it's safe to shut 'er down. I wait until my pyro cools to 350° before cutting the fuel. I've been told by a world class wrench that 300° or less is what you want but in the summer it could take a long time to cool that low.
    I irritate a lot of guards when they point to the sign that reads "turn off truck" and I yell that "my turbo needs to cool down first, ya want me to back up and wait?"
    Now if you drive a company truck, what does it really matter to you? You'll be in a different truck next year. Some cheapo used fleet truck buyer will end up with it in a few years.
  10. 123456
    123456 Road Train Member
    10,555
    5,748
    Oct 22, 2010
    32179
    Another old wise tale !!!!!!!
  11. earthmover
    563
    20
    Jan 27, 2009
    hey semi crazy i can spell but i don't type a lot dumb ### are would like me to spell that the right way for you...
