Idling at night
Discussion in 'Ask An Owner Operator' started by Jbrown87, Jun 4, 2024.
  1. Jbrown87
    Jbrown87 Light Load Member
    153
    333
    Nov 7, 2023
    Hey guys do you idle your trucks at night , when I was a company driver I did it but now that I pay for fuel I’m kind of not wanting to. But it doesn’t seem like it’s using that much fuel. I’m new to this so I want to save as much as I can but it’s got some places an o am so used to it for sleeping. Wondering. What you all do
    blairandgretchen and 77fib77 Thank this.
  3. 86scotty
    86scotty Road Train Member
    4,718
    12,962
    Aug 27, 2017
    Appalachia
    APU. Diesel APUs supposedly use about a gallon a night while your truck uses about a gallon an hour.
    They aren't cheap though. Idling a modern emissions truck isn't cheap either. You'll likely have DPF related problems sooner than later.
  4. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Buy a generator and portable ac unit. Get a 4000 watt. They're the same size as 2000 for the same price roughly.
    Wish I could say buy a diesel generator but they're pricey.
    There's a few threads on that.
    I believe the FL I last used was about a half gallon. Maybe a little more. Every truck before that was close to a gallon.
    Per hour
    Rideandrepair and Jbrown87 Thank this.
  5. Diesel Dave
    9,712
    33,144
    Jan 20, 2010
    Hesperia, Ca.
    If you idle, kick up the Rpm’s.
  6. 77fib77
    77fib77 Road Train Member
    11,693
    77,228
    Jul 7, 2010
    St Louis
    Opti idle it turns on and off the engine for cabin comfort. It hits 72 turns off the, Hits 80 F and turns on again. That being said, I might buy a portable AC and use a generator that I have in my headache rack. I have an ac unit at home, but I'm out and about now. The idling doesn't help the emissions system.
  7. Diesel Dave
    9,712
    33,144
    Jan 20, 2010
    Hesperia, Ca.
  8. flood
    flood Road Train Member
    4,169
    4,051
    Dec 25, 2010
    1st there is zero reason to hight idle a truck newer that 2006.
    2nd desel apu's use 4-6 gallons of fuel per 10 break depending on air temp.
    3rd a new apu run $14-$15
    4th ever hear the saying "cheap drivers aren't good, good drivers aren't cheap"... well cheap genurator's don't last, good genurators do. 4,000 watt suitcase genurators A per their website can't run a portable ac for a 10hr break with you having to refuel it. B the warranty on them is crap
    5th your truck uses about 7-8 gallons per 10 hour
  9. wore out
    wore out Numbered Classic
    17,375
    215,860
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    You’re showing our age……I keep wanting to say I sorta miss those days……but I really don’t not really
  10. Joeziah
    Joeziah Light Load Member
    176
    131
    Jan 2, 2016
    APU is a good investment. Recommend ComfortPro.
    Takes about 3 years to pay for itself if you sit a lot between loads. However not dealing with emissions issues or excessive wear on your main money maker is well worth it.
    I've spent about 20k between my APU, Lithium battery bank, inverters, dc/dc charger, solar panels/charger, Ac-dc charger and an upgraded 400amp alternator.
    Its paid for itself twice over in 5 years and has plenty of life left in all the components. Very low idle time on my engine so its gonna last a very long time before it needs a rebuild.
    By the way, a gen 2 Dynasys just running A/C will burn a gallon of diesel for every 4 hours of run time. Since it auto starts and stops you can usually get away with about 30-40% run time at night so you are looking at 1-1.5 gallons over a 10 hour break. I do NOT recommend a gen 2 Dynasys though....
    Blagoje and Jbrown87 Thank this.
