Idling truck at night
Discussion in 'Experienced Truckers' Advice' started by BenRauls, Oct 11, 2009.
  1. BenRauls
    BenRauls Bobtail Member
    11
    I've been a local driver for 2 years, just started with a new company. I'm still local, but once in a while i need to sleep in the truck. I have to idle to keep the heat going, do I idle or bump it up a little a little bit? how much?
    Ben
  3. Allow Me.
    10,773
    12,603
    May 28, 2009
    Rancho Mirage, Ca.
    Yes, you need to be idling at about 1000 rpm to lubricate the top end of the engine.
  4. ampm wayne
    ampm wayne Heavy Load Member
    945
    746
    Jan 13, 2009
    bloomington,in
    I agree. I idle at 1000 rpm.
  5. Ebola Guy
    Ebola Guy Heavy Load Member
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    If I idle, I kick it up just enough to make it a smooth idle. Sometimes it takes just a couple ticks on the cruise to get that done.
  6. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    depends on the truck, my old Mack in order to keep the oil pressure above 15 psi I had to idle it at 800 to 900 to prevent engine damage if idling more than 90 minutes. My new truck is "clean idle certified" so the computer will override and turn my engine back to 600 rpms if I hi-idle more than 90 minutes. But, at 600 rpms, oil pressure is in the 30's.
  7. chief
    chief Heavy Load Member
    851
    284
    Jul 15, 2007
    Flavor Country, NC
    I did not know that. I guess my day hasn't been wasted since I learned something new.
  8. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,869
    Sep 18, 2007
    Weatherford, TX
    Are you is day cab or sleeper? It is against the law to sleep in a day cab. What kind of truck you driving. Make engine etc.
  9. Sad_Panda
    Sad_Panda Road Train Member
    1,056
    312
    Dec 2, 2006
    You mean that he can't LOG it as sleeper.
    :biggrin_25513:
  10. oneshot
    oneshot Medium Load Member
    626
    248
    Feb 28, 2009
    mississippi
    Thats what i do,bump it up to about 725 to make it smooth.No engine trouble in 20yrs doing this.I also run cat.Others might b different.
