In my 2017 I have to turn the key 5-6 times before it catches to start. Any ideas? It’s getting worse before it would start with two turns
Ignition
Discussion in 'International Forum' started by fredrd, Jul 26, 2019.
Same thing happened to my wife’s car, had to have the tumbler replaced
figure out of if theres a certain way u need to turn the key to get it to engage, if so then yeah u need a new ignition barrel
Might be a bad starter
Starter checked out ok
Corrosion in the battery leads bad or loose ground loose relay
If it has a auto it could be the trans
10 speed
