impedance matching Transformers for audio
Discussion in 'CB Radio Forum' started by rabbiporkchop, Apr 13, 2016.
  1. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Does anybody happen to know how to reverse engineer a pre-existing miniature audio Transformer and build a new one from scratch with identical characteristics?
    TheDude1969 Thanks this.
  3. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    sounds like a job for Chris Tarnovsky :p
  4. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    It looks like integrated circuits are his specialty. Winding Transformers is a whole different ballgame and it's pretty much an art form.
    I know the primary winding is half as many wraps or turns as the secondary winding for a 4:1 impedance ratio. Frequency response is also critical and I don't even know how to factor that into the equation
  5. Ridgeline
    22,727
    123,466
    Yes.
    But I don't have time.
    Winding transformers is easy once you know how.
    Done enough of them in my life time.
    Got a setup to test and map transformers for prototyping. You can build one too with a frequency generator and a bunch of parts.
    I don't have time to explain what, why or how, but here are a few links for you.
    http://jensen-transformers.com/wp-content/uploads/2014/09/Audio-Transformers-Chapter.pdf
    http://www.learnabout-electronics.org/ac_theory/transformers04.php
    http://www.radioremembered.org/outimp.htm
    A majority of "miniature" audio stuff is OTS or can be ordered from places like Mouser by the way unless you are building some kickbutt tube amp - then you have to go to Erik Johansen or someone like that who does $300 transformers in chrome.
  6. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    I've already seen some high-dollar Transformers made in Sweden for recording industry but that's just a little out of my price range especially since Telex used to sell replacement Transformers for $2.50 a piece.
  7. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Mouser doesn't seem to have anything that quite fits the criteria
  8. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    Already read that Bill Whitlock book although most of that stuff went over my head.
  9. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    I wonder if anybody happens to know where to locate a miniature audio Transformer with a 4:1 impedance ratio suitable for matching a 150 ohm element to a 600 ohm input something along the lines of this[​IMG]
    Reason for edit: impedance ratio
  10. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    I'm also looking for a miniature audio Transformer with a 2.5:1 impedance ratio for my AKG D 58 which is 240 ohms
