In cab lift axle control
Discussion in 'Heavy Haul Trucking Forum' started by 7.3 cowboy, Jan 2, 2014.
  1. 7.3 cowboy
    7.3 cowboy Light Load Member
    210
    59
    Mar 4, 2013
    How are you guys controlling your in cab lift axles on a trailer ?
  3. GOV'T_Trucker
    GOV'T_Trucker Heavy Load Member
    782
    668
    May 28, 2011
    Our trucks are wired into the TRL AUX .....
  4. 7.3 cowboy
    210
    59
    Mar 4, 2013
    Just a electric switch that powers a solenoid?
  5. GOV'T_Trucker
    782
    668
    May 28, 2011
    Yes that's all it does... The TRL AUX switch in the cab would control the AUX PIN on the trailer which would be wired to the lift axle solenoid... Most lift axles can be manually controlled from the trailer as well but if the axles don't steer then this wouldn't be a good choice because you can rip a tire right off the rim when making a turn with a heavy loaded trailer...
    EverLuc and 7.3 cowboy Thank this.
  6. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    The other option besides electric is to use a third glad hand. Run the line to a relay valve for your lift.
    EverLuc Thanks this.
  7. Markvfl
    Markvfl Road Train Member
    1,103
    338
    Nov 29, 2007
    Apopka, FL
    If you're going to CA your lift axle controls cannot be inside the cab and axle and controls must be state certified. There are two inspectors for the whole state, 1 in the north and 1 in the south.
  8. 7.3 cowboy
    210
    59
    Mar 4, 2013
    I run missouri Kansas Iowa Nebraska Arkansas Oklahoma
  9. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    911
    Mar 16, 2013
    Mine on my flatbed (and every other spread I've pulled). Is just a switch on the dash with another pig tail that plugs into the trailer and it lets the pressure off the front or rear axle depending on the way it's setup. Hauling cattle I had two switches one for the front one for the rear. She I had to do axle weights I'd flip the front switch when I had to axle the front one and flip it back down and flip up the back one when I axles the rear axle. It was quite the setup. But that's why there illegal in some states cause we used to do that.
    Caterpillar Cowboy Thanks this.
  10. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    every trailer i've hauled. one otr and rest were local companies.
    all had manual valves inside a plastic box on the trailer.
  11. SheepDog
    SheepDog Road Train Member
    3,482
    2,084
    Nov 30, 2008
    Sand Lake, MI
    I had no idea about CA,,sheesh, that state is just fricken stupid. Anyway, nice read on how different the setups can be.
