Increasing MPG pete 389
Discussion in 'Peterbilt Forum' started by Wespipes, Feb 2, 2020.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    Been trying to find ways to increase MPG.
    1st, 19' pete 389 70k miles mid roof 3.25 gears 18 speed 11r24.5's cummins 565 1850.
    I'm averaging 5.5-6.5, 5.8 seems to be the norm
    So I'm looking at the bully dog tuner, after market manifold or intake, maybe maybe upgraded air filters. Just curious on what others have done to help. If any of what I mentioned is even worth it or even helps.
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Keep a light foot on the skinny pedal and watch your boost gauge, lower boost equals better fuel mileage.
    Ssgtkevin, LoneRanger, alds and 3 others Thank this.
  4. Wespipes
    1,037
    1,816
    Jul 14, 2019
    I try to keep it under 20
    Bakerman and Deere hunter Thank this.
  5. Snow Monster
    Snow Monster Medium Load Member
    543
    1,297
    Feb 9, 2019
    Before you start spending money, maybe for nothing, try this.
    Keep it under 70 mph and under 1500 rpm.
    I drove a 1996 W9 with a 3406E @ 550 hp, 3:25's on 22.5 rubber and that truck was driven below 1400 rpm at cruising speed, (65 to 68 mph), one of 20 trucks with a fleet average of 6.7 mpg.
    Your truck is a little faster with big rubber and if you're only pulling 80k or less try cruising between 1250 and 1400 rpm and play with it.
    If you're bucking wind or on a long slow rising grade, and the engine is working try dropping a gear and see what that does.
    An estimate on my part, that truck should still run 65 to 68 mph at 1500 rpm or less if you drop a gear and you should see a drop in EGT and turbo boost under heavy pulling conditions.
    Maybe try both throttle programs to see which one best fits your driving style or you prefer.
    I suggest you optimize what you have before you start changing things, so if you do change something you'll know for sure what and how much you gained.
    Other than that, make sure your filters are clean and your tire pressures are optimized, happy motoring.
    alds and Wespipes Thank this.
  6. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    279
    Nov 24, 2019
    What are you pulling?
    What speed and where are you driving?
    Speed eats up fuel mileage.
  7. Zack.Boswell
    Zack.Boswell Bobtail Member
    4
    I know this is an old thread, but I wanted to continue the conversation on Bully dog tuners. I’ve seen a lot of people saying to get them or to not get them. But I’m curious to hear anyone’s comments on how long they have been using them. Are they good tunes to use long term? It’s all good if you can pass everyone up a hill.. But how many times can you climb that hill for the years to come? Looking forward to any replies.
    Thanks
  8. SmoothBore
    SmoothBore Medium Load Member
    451
    709
    Jun 8, 2011
    The Desert
    Trade it in for a cascadia, problem solved.
  9. Cat sdp
    Cat sdp . .
    21,302
    76,171
    Apr 8, 2012
    Orion's Belt
    pfffft……
  10. Zack.Boswell
    4
    Haha.. funny..
