Inflating Tires?
Discussion in 'Questions From New Drivers' started by Dye Guardian, Mar 30, 2015.
  1. Dye Guardian
    Dye Guardian Road Train Member
    1,329
    12,583
    Jan 10, 2015
    North
    While in school, I was told a driver should never attempt to fill tires as it is very dangerous and you run a risk of the tire blowing up as you fill it. My instructor is/was only ever a company driver, so his mentality may very well be different than an O/O. "Just let someone who's certified deal with it, don't touch it". What do you all think? Clearly there are drivers who will fill their tires when needed. Is the danger real here?
  3. Vilhiem
    Vilhiem Road Train Member
    3,992
    10,904
    Oct 6, 2014
    I'm a company driver...carry a sledgehammer, and tire pressure gauge.
    If you overfill, sure there can be an issue. If you're under filled, again an issue...
    Carry a tire pressure gauge and don't inflate them more than they are rated for. As for needing an expert... Well, if you can inflate your car tires and know where your valve stems are, if you need a certified person to do it, then you may be certifiable yourself.
    P.s. There's a great deal of company drivers who have the mentality of, "let the company handle it since they pay." Don't go and fill your own fuel tank, but if you have a problem that you can resolve...solve it. (As long as you know what you're doing.). If it costs you something, ask to be reimbursed. If they won't reimburse it, find a new company.
    u4icwargasm Thanks this.
  4. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    Nothing to worry about, just dont put more then 100 lbs of air pressure, give or take. But If you see a big bubble forming then run!
  5. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    There’s a “certification” for inflating a tire?
    I guess it’s possible, probably from the same origination that certifies wiping your butt or breathing.
    u4icwargasm, Starboyjim, 201 and 2 others Thank this.
  6. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Wait for a "certified" tire filler?? That's simply ridiculous and untrue.
    Now there was significant danger back in the days of the old split rims, when reinstalling the rim ring and inflating the tire.
    But today's modern tires are much safer to fill, unless you see any damage to the tire (sidewalls especially, but also tread).
    It's far more dangerous to travel with a severely deflated tire than to inflate it to it's proper psi.
    The main caution would be not to inflate a low tire that has just come off the road and is still hot/overheated.
    Allow it to sit awhile and cool, before inflating, just to be safe.
    Here's a link to a good tire article and one to an online tire pressure "calculator", btw.
    http://www.truckinginfo.com/channel/maintenance/article/story/2013/08/the-magic-number.aspx
    http://www.yokohamatire.com/air_pressure_calculator#
  7. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    At my company, we drivers are lucky that we have the Hendrickson tire inflation monitoring/inflation system for our trailers.
    As for our tractors, All i have to do when I get to my location, is my pre-trip, and if a tire is under-inflated (on the tractor), I take it 1/2 a mile to Penske, where they have the air hose. I have a heavy duty truck tire "pencil style" air gauge, and I check my tires on the tractor weekly, and thump them several times a night at my stops. Never know when I'll be picking up a nail, butter-knife, piece of wood, etc,etc.
    Always check tire pressures when the tires are either stone cold (before you start), or most certainly when they have had a chance to cool, for about ( I think) 4 hours?
    And NEVER let air out of a tire, when it is warm,( the tire being warm, not the ambient air outside) as the air inside the tire expands as it warms up while driving, and when it cools, it will go back to a normal reading.
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Does sound like a hold over from the old split rim days--and since it was in training it may have as much to do w/that places insurance etc....
  9. 201
    201 Road Train Member
    12,829
    26,420
    Apr 16, 2014
    high plains colorado
    Hi Dye, every once in a while a thread comes along that REALLY makes me wonder, who is driving America's trucks with an attitude like that. I'm baffled to be even commenting on this, but if you're afraid to fill a tire, (or too lazy, which sounds like your instructors case) you shouldn't be in a truck. Tires have always been the FIRST thing to check, there's 18 of them, for heavens sake. If there's a low one, get it right BEFORE leaving. I had an air hose that I coupled to my glad hand on the truck, and always made sure my tires were full. I only had 1 split rim let go near me in all my years of trucking, and never a tubeless.( although, I'm sure it happens) It's a good time to look at the tires too, nails, sidewalls. I know tire technology has come a long way, and it's easy to forget about your tires, but coming from a time where 1 or 2 flats a week was normal, I just always made sure my tires were right,,,,,certified tire inflator, of course, why didn't I think of that?:biggrin_2559:
    Starboyjim Thanks this.
  10. G.Anthony
    4,564
    5,952
    Dec 10, 2014
    Although none of us were there to hear the comment, "certified", I have to wonder if the former trainer was referring to a certified mechanic? Or at the very least someone in the garage, that can sign off the job work order? I think if memory serves me, and ONLY as an example, we are told not to adjust our brakes, unless we are certified to do so, so maybe the former instructor was also referring to that as well? You know, lump it all into one category?
    Just thinking out loud here.
    Lepton1 and Vilhiem Thank this.
  11. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    I carry a pressure guage and an inflation hose kit on a cable reel. I'm certified according to some but not for tire inflation.
