I have a trailer with the meritor inflation system. If I set the pressure to 120 will it allow the pressure to rise to say 130 when the tire warms up, or does it bleed off pressure to maintain 120?
Inflation systems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tnc110, Apr 6, 2026 at 10:03 PM.
I had two trailers with the Hendrickson Tire Max inflation system 2016 and 2022. They were only to air a system up and not deflate any air. In 2023 when I ordered another trailer I had the option of getting a Hendrickson Tire Max Pro for several hundred dollars more than the Tire Max. The Pro also let air out when the tires warmed up. I got the Pro system because it seemed like a great upgrade to me. Not sure about your system but that option is currently available on Hendrickson systems.Last edited: Apr 6, 2026 at 10:25 PM
interesting, so there are options.
Personally I wouldn’t want it letting any air out. In the summer time you need to let the pressure build. Especially when heavy. The lower the pressure, the more the tire flexes every revolution, the more heat is produced. Heat causes tires to fail. Summer pressures should reach 140 or higher when warm. If the inflation system bleeds the pressure then that’s not good. -
I guess we have different ways of doing things then. I believe a more consistent pressure helped in my operation and thus opted for the system that kept a more constant pressure. In my opinion some extra pressure was good but in my tires that didn’t let air out in 90&100 degree temps they had way too much air in them according to my TPMS. I only have one year of use with the new system but all tires seem to wear better than the other two trailers.Last edited: Apr 6, 2026 at 10:45 PM
krupa530 Thanks this. -
You have to disregard the tpms when it’s giving you a high pressure alarm. Tire manufacturers don’t post max pressures. Tires can hold 100s of psi safely. You will have far more problems running lower pressures than running higher pressures.
I track and document tire wear religiously and can only speak from my point of view. If I order another trailer it will have the Tire max Pro.
